22 #ifndef LIBBSP_ARM_LPC176X_GPIO_DEFS_H    23 #define LIBBSP_ARM_LPC176X_GPIO_DEFS_H    32 #define LPC176X_GPIO_BASE_ADDR 0x40028000U    33 #define LPC176X_GPIO_INTERRUPT_STATUS 0x40028080U    35 #define LPC176X_IOPIN0 ( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR + \    37 #define LPC176X_IOSET0 ( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR + \    39 #define LPC176X_IODIR0 ( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR + \    41 #define LPC176X_IOCLR0 ( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR + \    43 #define LPC176X_IOPIN1 ( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR + \    45 #define LPC176X_IOSET1 ( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR + \    47 #define LPC176X_IODIR1 ( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR + \    49 #define LPC176X_IOCLR1 ( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR + \    53 #define LPC176X_IO0_INT_EN_R ( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR \    55 #define LPC176X_IO0_INT_EN_F ( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR \    57 #define LPC176X_IO0_INT_STAT_R ( *(volatile uint32_t *) ( \    58                                    LPC176X_GPIO_BASE_ADDR \    60 #define LPC176X_IO0_INT_STAT_F ( *(volatile uint32_t *) ( \    61                                    LPC176X_GPIO_BASE_ADDR \    63 #define LPC176X_IO0_INT_CLR ( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR \    65 #define LPC176X_IO2_INT_EN_R ( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR \    67 #define LPC176X_IO2_INT_EN_F ( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR \    69 #define LPC176X_IO2_INT_STAT_R ( *(volatile uint32_t *) ( \    70                                    LPC176X_GPIO_BASE_ADDR \    72 #define LPC176X_IO2_INT_STAT_F ( *(volatile uint32_t *) ( \    73                                    LPC176X_GPIO_BASE_ADDR \    75 #define LPC176X_IO2_INT_CLR ( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR \    77 #define LPC176X_IO_INT_STAT ( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR \    80 #define LPC176X_RESERVED_ISR_FUNCT_SIZE 2U    81 #define LPC176X_RESERVED_ISR_FUNCT_MAX_SIZE 5U    83 #define LPC176X_MAX_PORT_NUMBER 160U    84 #define LPC176X_SET_BIT( reg, pin, value ) \    85   reg = ( reg & ~( 1U << pin ) ) | ( ( value & 1U ) << pin )    87 #define LPC176X_INT_STATUS ( *(volatile uint32_t *) \    88                              ( LPC176X_GPIO_INTERRUPT_STATUS ) )    89 #define LPC176X_INT_STATUS_P0 1U    90 #define LPC176X_INT_STATUS_P2 ( 1U << 2U )    91 #define LPC176X_INT_ENABLE 1U    92 #define LPC176X_INT_DISABLE 0U    94 #define LPC176X_IRQ_EINT_3 21U    96 #define LPC176X_PIN_BIT( pin ) ( 1U << pin )   104   LPC176X_GPIO_FUNCTION_INPUT,
   105   LPC176X_GPIO_FUNCTION_OUTPUT,
   106   LPC176X_GPIO_FUNCTION_COUNT
   116   LPC176X_GPIO_INTERRUPT_DISABLE,
   117   LPC176X_GPIO_INTERRUPT_RISING,
   118   LPC176X_GPIO_INTERRUPT_FALLING,
   119   LPC176X_GPIO_INTERRUPT_BOTH,
   120   LPC176X_GPIO_INTERRUPT_COUNT
   134   LPC176X_GPIO_PORTS_COUNT
   144   LPC176X_FIO0_BASE_ADDRESS = 0x2009C000U,
   145   LPC176X_FIO1_BASE_ADDRESS = 0x2009C020U,
   146   LPC176X_FIO2_BASE_ADDRESS = 0x2009C040U,
   147   LPC176X_FIO3_BASE_ADDRESS = 0x2009C060U,
   148   LPC176X_FIO4_BASE_ADDRESS = 0x2009C080U,
   158   LPC176X_IO0_INT_BASE_ADDRESS = 0x40028084U,
   159   LPC176X_IO2_INT_BASE_ADDRESS = 0x400280A4U,
 lpc176x_gpio_address
Addresses for a GPIO.
Definition: gpio-defs.h:143
volatile uint32_t EnR
Interrupt Enable for Rising edge.
Definition: gpio-defs.h:181
volatile uint32_t StatR
Definition: gpio-defs.h:169
lpc176x_gpio_ports
The ports for a GPIO.
Definition: gpio-defs.h:128
lpc176x_gpio_interrupt
The interrupt sources edge for a GPIO.
Definition: gpio-defs.h:115
volatile uint32_t EnF
Interrupt Enable for Falling edge.
Definition: gpio-defs.h:185
Definitions types used by some devices in common.
volatile uint32_t StatF
Definition: gpio-defs.h:173
A registered interrupt function for the pin 'pin'.
Definition: gpio-defs.h:203
lpc176x_gpio_direction
The direction of the GPIO port (input or output).
Definition: gpio-defs.h:103
GPIO Interrupt register map.
Definition: gpio-defs.h:165
lpc176x_pin_number pin
Pin board.
Definition: gpio-defs.h:207
uint32_t lpc176x_pin_number
A pin of the board.
Definition: common-types.h:32
void(* lpc176x_gpio_interrupt_function)(const lpc176x_pin_number pin, const lpc176x_gpio_interrupt edge)
A function that attends an interrupt for GPIO.
Definition: gpio-defs.h:195
volatile uint32_t Clr
Interrupt Clear.
Definition: gpio-defs.h:177
lpc176x_interrupt_address
Addresses for the two interrupts.
Definition: gpio-defs.h:157
