23 #ifndef LIBBSP_ARM_LPC32XX_EMC_H    24 #define LIBBSP_ARM_LPC32XX_EMC_H    48 #define SDRAMCLK_CLOCKS_DIS BSP_BIT32(0)    49 #define SDRAMCLK_DDR_MODE BSP_BIT32(1)    50 #define SDRAMCLK_DDR_DQSIN_DELAY(val) BSP_FLD32(val, 2, 6)    51 #define SDRAMCLK_RTC_TICK_EN BSP_BIT32(7)    52 #define SDRAMCLK_SW_DDR_CAL BSP_BIT32(8)    53 #define SDRAMCLK_CAL_DELAY BSP_BIT32(9)    54 #define SDRAMCLK_SENSITIVITY_FACTOR(val) BSP_FLD32(val, 10, 12)    55 #define SDRAMCLK_DCA_STATUS BSP_BIT32(13)    56 #define SDRAMCLK_COMMAND_DELAY(val) BSP_FLD32(val, 14, 18)    57 #define SDRAMCLK_SW_DDR_RESET BSP_BIT32(19)    58 #define SDRAMCLK_PIN_1_FAST BSP_BIT32(20)    59 #define SDRAMCLK_PIN_2_FAST BSP_BIT32(21)    60 #define SDRAMCLK_PIN_3_FAST BSP_BIT32(22)    70 #define EMC_AHB_PORT_BUFF_EN BSP_BIT32(0)    80 #define EMC_AHB_TIMEOUT(val) BSP_FLD32(val, 0, 9)    90 #define SDRAM_ADDR_ROW_16MB(val) ((uint32_t) (val) << 10)    91 #define SDRAM_ADDR_ROW_32MB(val) ((uint32_t) (val) << 11)    92 #define SDRAM_ADDR_ROW_64MB(val) ((uint32_t) (val) << 11)    94 #define SDRAM_ADDR_BANK_16MB(ba1, ba0) \    95   (((uint32_t) (ba1) << 23) | ((uint32_t) (ba0) << 22))    96 #define SDRAM_ADDR_BANK_32MB(ba1, ba0) \    97   (((uint32_t) (ba1) << 23) | ((uint32_t) (ba0) << 24))    98 #define SDRAM_ADDR_BANK_64MB(ba1, ba0) \    99   (((uint32_t) (ba1) << 25) | ((uint32_t) (ba0) << 24))   101 #define SDRAM_MODE_16MB(mode) \   102   (SDRAM_ADDR_BANK_16MB(0, 0) | SDRAM_ADDR_ROW_16MB(mode))   103 #define SDRAM_MODE_32MB(mode) \   104   (SDRAM_ADDR_BANK_32MB(0, 0) | SDRAM_ADDR_ROW_32MB(mode))   105 #define SDRAM_MODE_64MB(mode) \   106   (SDRAM_ADDR_BANK_64MB(0, 0) | SDRAM_ADDR_ROW_64MB(mode))   108 #define SDRAM_EXTMODE_16MB(mode) \   109   (SDRAM_ADDR_BANK_16MB(1, 0) | SDRAM_ADDR_ROW_16MB(mode))   110 #define SDRAM_EXTMODE_32MB(mode) \   111   (SDRAM_ADDR_BANK_32MB(1, 0) | SDRAM_ADDR_ROW_32MB(mode))   112 #define SDRAM_EXTMODE_64MB(mode) \   113   (SDRAM_ADDR_BANK_64MB(1, 0) | SDRAM_ADDR_ROW_64MB(mode))   115 #define SDRAM_MODE_BURST_LENGTH(val) BSP_FLD32(val, 0, 2)   116 #define SDRAM_MODE_BURST_INTERLEAVE BSP_BIT32(3)   117 #define SDRAM_MODE_CAS(val) BSP_FLD32(val, 4, 6)   118 #define SDRAM_MODE_TEST_MODE(val) BSP_FLD32(val, 7, 8)   119 #define SDRAM_MODE_WRITE_BURST_SINGLE_BIT BSP_BIT32(9)   121 #define SDRAM_EXTMODE_PASR(val) BSP_FLD32(val, 0, 2)   122 #define SDRAM_EXTMODE_DRIVER_STRENGTH(val) BSP_FLD32(val, 5, 6)   135   uint32_t sdramclk_ctrl;
   136   uint32_t nop_time_in_us;
 Definition: deflate.c:115
Definition: intercom.c:74
unsigned size
Definition: tte.h:74
