#define  | SDRAMCLK_CLOCKS_DIS   BSP_BIT32(0) |
#define  | SDRAMCLK_DDR_MODE   BSP_BIT32(1) |
#define  | SDRAMCLK_DDR_DQSIN_DELAY(val)   BSP_FLD32(val, 2, 6) |
#define  | SDRAMCLK_RTC_TICK_EN   BSP_BIT32(7) |
#define  | SDRAMCLK_SW_DDR_CAL   BSP_BIT32(8) |
#define  | SDRAMCLK_CAL_DELAY   BSP_BIT32(9) |
#define  | SDRAMCLK_SENSITIVITY_FACTOR(val)   BSP_FLD32(val, 10, 12) |
#define  | SDRAMCLK_DCA_STATUS   BSP_BIT32(13) |
#define  | SDRAMCLK_COMMAND_DELAY(val)   BSP_FLD32(val, 14, 18) |
#define  | SDRAMCLK_SW_DDR_RESET   BSP_BIT32(19) |
#define  | SDRAMCLK_PIN_1_FAST   BSP_BIT32(20) |
#define  | SDRAMCLK_PIN_2_FAST   BSP_BIT32(21) |
#define  | SDRAMCLK_PIN_3_FAST   BSP_BIT32(22) |
#define  | EMC_AHB_PORT_BUFF_EN   BSP_BIT32(0) |
#define  | EMC_AHB_TIMEOUT(val)   BSP_FLD32(val, 0, 9) |
#define  | SDRAM_ADDR_ROW_16MB(val)   ((uint32_t) (val) << 10) |
#define  | SDRAM_ADDR_ROW_32MB(val)   ((uint32_t) (val) << 11) |
#define  | SDRAM_ADDR_ROW_64MB(val)   ((uint32_t) (val) << 11) |
#define  | SDRAM_ADDR_BANK_16MB(ba1,  ba0)   (((uint32_t) (ba1) << 23) | ((uint32_t) (ba0) << 22)) |
#define  | SDRAM_ADDR_BANK_32MB(ba1,  ba0)   (((uint32_t) (ba1) << 23) | ((uint32_t) (ba0) << 24)) |
#define  | SDRAM_ADDR_BANK_64MB(ba1,  ba0)   (((uint32_t) (ba1) << 25) | ((uint32_t) (ba0) << 24)) |
#define  | SDRAM_MODE_16MB(mode)   (SDRAM_ADDR_BANK_16MB(0, 0) | SDRAM_ADDR_ROW_16MB(mode)) |
#define  | SDRAM_MODE_32MB(mode)   (SDRAM_ADDR_BANK_32MB(0, 0) | SDRAM_ADDR_ROW_32MB(mode)) |
#define  | SDRAM_MODE_64MB(mode)   (SDRAM_ADDR_BANK_64MB(0, 0) | SDRAM_ADDR_ROW_64MB(mode)) |
#define  | SDRAM_EXTMODE_16MB(mode)   (SDRAM_ADDR_BANK_16MB(1, 0) | SDRAM_ADDR_ROW_16MB(mode)) |
#define  | SDRAM_EXTMODE_32MB(mode)   (SDRAM_ADDR_BANK_32MB(1, 0) | SDRAM_ADDR_ROW_32MB(mode)) |
#define  | SDRAM_EXTMODE_64MB(mode)   (SDRAM_ADDR_BANK_64MB(1, 0) | SDRAM_ADDR_ROW_64MB(mode)) |
#define  | SDRAM_MODE_BURST_LENGTH(val)   BSP_FLD32(val, 0, 2) |
#define  | SDRAM_MODE_BURST_INTERLEAVE   BSP_BIT32(3) |
#define  | SDRAM_MODE_CAS(val)   BSP_FLD32(val, 4, 6) |
#define  | SDRAM_MODE_TEST_MODE(val)   BSP_FLD32(val, 7, 8) |
#define  | SDRAM_MODE_WRITE_BURST_SINGLE_BIT   BSP_BIT32(9) |
#define  | SDRAM_EXTMODE_PASR(val)   BSP_FLD32(val, 0, 2) |
#define  | SDRAM_EXTMODE_DRIVER_STRENGTH(val)   BSP_FLD32(val, 5, 6) |
