#define  | EMC_DYN_CHIP_COUNT   4 |
#define  | EMC_STATIC_CHIP_COUNT   4 |
#define  | EMC_CTRL_E   BSP_BIT32(0) |
#define  | EMC_CTRL_M   BSP_BIT32(0) |
#define  | EMC_CTRL_L   BSP_BIT32(2) |
#define  | EMC_DYN_CTRL_CE   BSP_BIT32(0) |
#define  | EMC_DYN_CTRL_CS   BSP_BIT32(1) |
#define  | EMC_DYN_CTRL_SR   BSP_BIT32(2) |
#define  | EMC_DYN_CTRL_SRMCC   BSP_BIT32(3) |
#define  | EMC_DYN_CTRL_IMCC   BSP_BIT32(4) |
#define  | EMC_DYN_CTRL_MCC   BSP_BIT32(5) |
#define  | EMC_DYN_CTRL_I_MASK   BSP_MSK32(7, 8) |
#define  | EMC_DYN_CTRL_I_NORMAL   BSP_FLD32(0x0, 7, 8) |
#define  | EMC_DYN_CTRL_I_MODE   BSP_FLD32(0x1, 7, 8) |
#define  | EMC_DYN_CTRL_I_PALL   BSP_FLD32(0x2, 7, 8) |
#define  | EMC_DYN_CTRL_I_NOP   BSP_FLD32(0x3, 7, 8) |
#define  | EMC_DYN_CTRL_DP   BSP_BIT32(13) |
#define  | EMC_DYN_READ_CONFIG_SDR_STRAT(val)   BSP_FLD32(val, 0, 1) |
#define  | EMC_DYN_READ_CONFIG_SDR_POL_POS   BSP_BIT32(4) |
#define  | EMC_DYN_READ_CONFIG_DDR_STRAT(val)   BSP_FLD32(val, 8, 9) |
#define  | EMC_DYN_READ_CONFIG_DDR_POL_POS   BSP_BIT32(12) |
#define  | EMC_DYN_CFG_MD_LPC24XX(val)   BSP_FLD32(val, 3, 4) |
#define  | EMC_DYN_CFG_MD_LPC32XX(val)   BSP_FLD32(val, 0, 2) |
#define  | EMC_DYN_CFG_AM(val)   BSP_FLD32(val, 7, 14) |
#define  | EMC_DYN_CFG_B   BSP_BIT32(19) |
#define  | EMC_DYN_CFG_P   BSP_BIT32(20) |
#define  | EMC_DYN_RASCAS_RAS(val)   BSP_FLD32(val, 0, 3) |
#define  | EMC_DYN_RASCAS_CAS(val,  half)   BSP_FLD32(((val) << 1) | (half), 7, 10) |
