    RTEMS
    5.1
Go to the documentation of this file.   23 #ifndef LIBCPU_SHARED_UTILITY_H    24 #define LIBCPU_SHARED_UTILITY_H    28 #define BSP_BIT8(bit) \    29   ((uint8_t) (((unsigned int) 1) << (bit)))    31 #define BSP_MSK8(first_bit, last_bit) \    32   ((uint8_t) ((BSP_BIT8((last_bit) - (first_bit) + 1) - 1) << (first_bit)))    34 #define BSP_FLD8(val, first_bit, last_bit) \    36     ((((unsigned int) (val)) << (first_bit)) & BSP_MSK8(first_bit, last_bit)))    38 #define BSP_FLD8GET(reg, first_bit, last_bit) \    39   ((uint8_t) (((reg) & BSP_MSK8(first_bit, last_bit)) >> (first_bit)))    41 #define BSP_FLD8SET(reg, val, first_bit, last_bit) \    42   ((uint8_t) (((reg) & ~BSP_MSK8(first_bit, last_bit)) \    43     | BSP_FLD8(val, first_bit, last_bit)))    45 #define BSP_BIT16(bit) \    46   ((uint16_t) (((unsigned int) 1) << (bit)))    48 #define BSP_MSK16(first_bit, last_bit) \    49   ((uint16_t) ((BSP_BIT16((last_bit) - (first_bit) + 1) - 1) << (first_bit)))    51 #define BSP_FLD16(val, first_bit, last_bit) \    53     ((((unsigned int) (val)) << (first_bit)) & BSP_MSK16(first_bit, last_bit)))    55 #define BSP_FLD16GET(reg, first_bit, last_bit) \    56   ((uint16_t) (((reg) & BSP_MSK16(first_bit, last_bit)) >> (first_bit)))    58 #define BSP_FLD16SET(reg, val, first_bit, last_bit) \    59   ((uint16_t) (((reg) & ~BSP_MSK16(first_bit, last_bit)) \    60     | BSP_FLD16(val, first_bit, last_bit)))    62 #define BSP_BIT32(bit) \    63   ((uint32_t) (((uint32_t) 1) << (bit)))    65 #define BSP_MSK32(first_bit, last_bit) \    66   ((uint32_t) ((BSP_BIT32((last_bit) - (first_bit) + 1) - 1) << (first_bit)))    68 #define BSP_FLD32(val, first_bit, last_bit) \    70     ((((uint32_t) (val)) << (first_bit)) & BSP_MSK32(first_bit, last_bit)))    72 #define BSP_FLD32GET(reg, first_bit, last_bit) \    73   ((uint32_t) (((reg) & BSP_MSK32(first_bit, last_bit)) >> (first_bit)))    75 #define BSP_FLD32SET(reg, val, first_bit, last_bit) \    76   ((uint32_t) (((reg) & ~BSP_MSK32(first_bit, last_bit)) \    77     | BSP_FLD32(val, first_bit, last_bit)))    79 #define BSP_BIT64(bit) \    80   ((uint64_t) (((uint64_t) 1) << (bit)))    82 #define BSP_MSK64(first_bit, last_bit) \    83   ((uint64_t) ((BSP_BIT64((last_bit) - (first_bit) + 1) - 1) << (first_bit)))    85 #define BSP_FLD64(val, first_bit, last_bit) \    87     ((((uint64_t) (val)) << (first_bit)) & BSP_MSK64(first_bit, last_bit)))    89 #define BSP_FLD64GET(reg, first_bit, last_bit) \    90   ((uint64_t) (((reg) & BSP_MSK64(first_bit, last_bit)) >> (first_bit)))    92 #define BSP_FLD64SET(reg, val, first_bit, last_bit) \    93   ((uint64_t) (((reg) & ~BSP_MSK64(first_bit, last_bit)) \    94     | BSP_FLD64(val, first_bit, last_bit)))    96 #define BSP_BBIT8(bit) \    99 #define BSP_BMSK8(first_bit, last_bit) \   100   BSP_MSK8(7 - (last_bit), 7 - (first_bit))   102 #define BSP_BFLD8(val, first_bit, last_bit) \   103   BSP_FLD8(val, 7 - (last_bit), 7 - (first_bit))   105 #define BSP_BFLD8GET(reg, first_bit, last_bit) \   106   BSP_FLD8GET(reg, 7 - (last_bit), 7 - (first_bit))   108 #define BSP_BFLD8SET(reg, val, first_bit, last_bit) \   109   BSP_FLD8SET(reg, val, 7 - (last_bit), 7 - (first_bit))   111 #define BSP_BBIT16(bit) \   112   BSP_BIT16(15 - (bit))   114 #define BSP_BMSK16(first_bit, last_bit) \   115   BSP_MSK16(15 - (last_bit), 15 - (first_bit))   117 #define BSP_BFLD16(val, first_bit, last_bit) \   118   BSP_FLD16(val, 15 - (last_bit), 15 - (first_bit))   120 #define BSP_BFLD16GET(reg, first_bit, last_bit) \   121   BSP_FLD16GET(reg, 15 - (last_bit), 15 - (first_bit))   123 #define BSP_BFLD16SET(reg, val, first_bit, last_bit) \   124   BSP_FLD16SET(reg, val, 15 - (last_bit), 15 - (first_bit))   126 #define BSP_BBIT32(bit) \   127   BSP_BIT32(31 - (bit))   129 #define BSP_BMSK32(first_bit, last_bit) \   130   BSP_MSK32(31 - (last_bit), 31 - (first_bit))   132 #define BSP_BFLD32(val, first_bit, last_bit) \   133   BSP_FLD32(val, 31 - (last_bit), 31 - (first_bit))   135 #define BSP_BFLD32GET(reg, first_bit, last_bit) \   136   BSP_FLD32GET(reg, 31 - (last_bit), 31 - (first_bit))   138 #define BSP_BFLD32SET(reg, val, first_bit, last_bit) \   139   BSP_FLD32SET(reg, val, 31 - (last_bit), 31 - (first_bit))   141 #define BSP_BBIT64(bit) \   142   BSP_BIT64(63 - (bit))   144 #define BSP_BMSK64(first_bit, last_bit) \   145   BSP_MSK64(63 - (last_bit), 63 - (first_bit))   147 #define BSP_BFLD64(val, first_bit, last_bit) \   148   BSP_FLD64(val, 63 - (last_bit), 63 - (first_bit))   150 #define BSP_BFLD64GET(reg, first_bit, last_bit) \   151   BSP_FLD64GET(reg, 63 - (last_bit), 63 - (first_bit))   153 #define BSP_BFLD64SET(reg, val, first_bit, last_bit) \   154   BSP_FLD64SET(reg, val, 63 - (last_bit), 63 - (first_bit))
