RTEMS  5.1
Macros | Functions
Enhanced Direct Memory Access (eDMA). More...
#include <mpc55xx/edma.h>
#include <mpc55xx/mpc55xx.h>
#include <assert.h>
#include <bsp.h>
#include <bsp/fatal.h>
#include <bsp/irq.h>
#define EDMA_CHANNELS_PER_GROUP   32U
#define EDMA_GROUP_COUNT   ((EDMA_CHANNEL_COUNT + 31U) / 32U)
#define EDMA_GROUP_INDEX(channel)   ((channel) / EDMA_CHANNELS_PER_GROUP)
#define EDMA_GROUP_BIT(channel)   (1U << ((channel) % EDMA_CHANNELS_PER_GROUP))
#define EDMA_MODULE_INDEX(channel)   ((channel) / EDMA_CHANNELS_PER_MODULE)
void mpc55xx_edma_init (void)
rtems_status_code mpc55xx_edma_obtain_channel_by_tcd (volatile struct tcd_t *edma_tcd)
 Obtains an eDMA channel. More...
void mpc55xx_edma_release_channel_by_tcd (volatile struct tcd_t *edma_tcd)
rtems_status_code mpc55xx_edma_obtain_channel (edma_channel_context *ctx, unsigned irq_priority)
 Obtains an eDMA channel and registers the channel context. More...
void mpc55xx_edma_release_channel (edma_channel_context *ctx)
void mpc55xx_edma_copy (volatile struct tcd_t *edma_tcd, const struct tcd_t *source_tcd)
 Copies a source TCD to an eDMA TCD. More...
void mpc55xx_edma_copy_and_enable_hardware_requests (volatile struct tcd_t *edma_tcd, const struct tcd_t *source_tcd)
 Copies a source TCD to an eDMA TCD and enables hardware requests. More...
void mpc55xx_edma_sg_link (volatile struct tcd_t *edma_tcd, const struct tcd_t *source_tcd)
◆ mpc55xx_edma_copy()
void mpc55xx_edma_copy ( volatile struct tcd_t *  edma_tcd,
const struct tcd_t *  source_tcd
The DONE flag of the eDMA TCD is cleared before the actual copy operation. This enables the setting of channel link or scatter/gather options.
This function can be used to start the channel if the START flags is set in the source TCD.
◆ mpc55xx_edma_copy_and_enable_hardware_requests()
void mpc55xx_edma_copy_and_enable_hardware_requests ( volatile struct tcd_t *  edma_tcd,
◆ mpc55xx_edma_obtain_channel()
rtems_status_code mpc55xx_edma_obtain_channel ( edma_channel_context *  ctx,
The done handler of the channel context will be called
  • during minor or major loop completions if interrupts are enabled in the corresponding TCD, or
  • in case a channel error occurs.
An error status value not equal to zero indicates an error.
Return values
RTEMS_SUCCESSFULSuccessful operation.
RTEMS_RESOURCE_IN_USEThe channel is already in use.
RTEMS_IO_ERRORUnable to install interrupt handler for this channel.
◆ mpc55xx_edma_obtain_channel_by_tcd()
rtems_status_code mpc55xx_edma_obtain_channel_by_tcd ( volatile struct tcd_t *  edma_tcd)
Return values
