RTEMS  5.1
cpu.c File Reference
SPARC CPU Dependent Source. More...
#include <rtems/score/isr.h>
#include <rtems/score/tls.h>
#include <rtems/rtems/cache.h>
#define SPARC_ASSERT_OFFSET(field, off)
#define SPARC_ASSERT_ISF_OFFSET(field, off)
#define SPARC_ASSERT_FP_OFFSET(field, off)
#define HIGH_BITS_MASK   0xFFFFFC00
#define HIGH_BITS_SHIFT   10
#define LOW_BITS_MASK   0x000003FF
 SPARC_ASSERT_OFFSET (g5, G5)
 SPARC_ASSERT_OFFSET (g7, G7)
 RTEMS_STATIC_ASSERT (offsetof(Context_Control, l0_and_l1)==L0_OFFSET, Context_Control_offset_L0)
 RTEMS_STATIC_ASSERT (offsetof(Context_Control, l0_and_l1)+4==L1_OFFSET, Context_Control_offset_L1)
 SPARC_ASSERT_OFFSET (l2, L2)
 SPARC_ASSERT_OFFSET (l3, L3)
 SPARC_ASSERT_OFFSET (l4, L4)
 SPARC_ASSERT_OFFSET (l5, L5)
 SPARC_ASSERT_OFFSET (l6, L6)
 SPARC_ASSERT_OFFSET (l7, L7)
 SPARC_ASSERT_OFFSET (i0, I0)
 SPARC_ASSERT_OFFSET (i1, I1)
 SPARC_ASSERT_OFFSET (i2, I2)
 SPARC_ASSERT_OFFSET (i3, I3)
 SPARC_ASSERT_OFFSET (i4, I4)
 SPARC_ASSERT_OFFSET (i5, I5)
 SPARC_ASSERT_OFFSET (i6_fp, I6_FP)
 SPARC_ASSERT_OFFSET (i7, I7)
 SPARC_ASSERT_OFFSET (o6_sp, O6_SP)
 SPARC_ASSERT_OFFSET (o7, O7)
 SPARC_ASSERT_OFFSET (psr, PSR)
 SPARC_ASSERT_OFFSET (isr_dispatch_disable, ISR_DISPATCH_DISABLE_STACK)
 SPARC_ASSERT_ISF_OFFSET (psr, PSR)
 SPARC_ASSERT_ISF_OFFSET (pc, PC)
 SPARC_ASSERT_ISF_OFFSET (npc, NPC)
 SPARC_ASSERT_ISF_OFFSET (g1, G1)
 SPARC_ASSERT_ISF_OFFSET (g2, G2)
 SPARC_ASSERT_ISF_OFFSET (g3, G3)
 SPARC_ASSERT_ISF_OFFSET (g4, G4)
 SPARC_ASSERT_ISF_OFFSET (g5, G5)
 SPARC_ASSERT_ISF_OFFSET (g7, G7)
 SPARC_ASSERT_ISF_OFFSET (i0, I0)
 SPARC_ASSERT_ISF_OFFSET (i1, I1)
 SPARC_ASSERT_ISF_OFFSET (i2, I2)
 SPARC_ASSERT_ISF_OFFSET (i3, I3)
 SPARC_ASSERT_ISF_OFFSET (i4, I4)
 SPARC_ASSERT_ISF_OFFSET (i5, I5)
 SPARC_ASSERT_ISF_OFFSET (i6_fp, I6_FP)
 SPARC_ASSERT_ISF_OFFSET (i7, I7)
 SPARC_ASSERT_ISF_OFFSET (y, Y)
 SPARC_ASSERT_ISF_OFFSET (tpc, TPC)
 SPARC_ASSERT_FP_OFFSET (f0_f1, F0_F1)
 SPARC_ASSERT_FP_OFFSET (f2_f3, F2_F3)
 SPARC_ASSERT_FP_OFFSET (f4_f5, F4_F5)
 SPARC_ASSERT_FP_OFFSET (f6_f7, F6_F7)
 SPARC_ASSERT_FP_OFFSET (f8_f9, F8_F9)
 SPARC_ASSERT_FP_OFFSET (f10_f11, F10_F11)
 SPARC_ASSERT_FP_OFFSET (f12_f13, F12_F13)
 SPARC_ASSERT_FP_OFFSET (f14_f15, F14_F15)
 SPARC_ASSERT_FP_OFFSET (f16_f17, F16_F17)
 SPARC_ASSERT_FP_OFFSET (f18_f19, F18_F19)
 SPARC_ASSERT_FP_OFFSET (f20_f21, F20_F21)
 SPARC_ASSERT_FP_OFFSET (f22_f23, F22_F23)
 SPARC_ASSERT_FP_OFFSET (f24_f25, F24_F25)
 SPARC_ASSERT_FP_OFFSET (f26_f27, F26_F27)
 SPARC_ASSERT_FP_OFFSET (f28_f29, F28_F29)
 SPARC_ASSERT_FP_OFFSET (f30_f31, F30_F31)
 SPARC_ASSERT_FP_OFFSET (fsr, FSR)
 RTEMS_STATIC_ASSERT (sizeof(SPARC_Minimum_stack_frame)==SPARC_MINIMUM_STACK_FRAME_SIZE, SPARC_MINIMUM_STACK_FRAME_SIZE)
 RTEMS_STATIC_ASSERT (sizeof(CPU_Interrupt_frame) % CPU_ALIGNMENT==0, CPU_Interrupt_frame_alignment)
void _CPU_Initialize (void)
 CPU initialization. More...
uint32_t _CPU_ISR_Get_level (void)
 Returns the interrupt level of the executing thread. More...
void _CPU_ISR_install_raw_handler (uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler)
 SPARC specific raw ISR installer. More...
void _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
 SPARC specific RTEMS ISR installer. More...
void _CPU_Context_Initialize (Context_Control *the_context, uint32_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area)
const CPU_Trap_table_entry _CPU_Trap_slot_template
◆ SPARC_ASSERT_FP_OFFSET
#define SPARC_ASSERT_FP_OFFSET (   field,
  off
Value:
RTEMS_STATIC_ASSERT( \
offsetof(Context_Control_fp, field) == SPARC_FP_CONTEXT_OFFSET_ ## off, \
Context_Control_fp_offset_ ## field \
SPARC basic context.
Definition: cpu.h:194
◆ SPARC_ASSERT_ISF_OFFSET
#define SPARC_ASSERT_ISF_OFFSET (   field,
  off
Value:
offsetof(CPU_Interrupt_frame, field) == ISF_ ## off ## _OFFSET, \
CPU_Interrupt_frame_offset_ ## field \
Interrupt stack frame (ISF).
Definition: cpu.h:191
◆ SPARC_ASSERT_OFFSET
#define SPARC_ASSERT_OFFSET (   field,
  off
Value:
offsetof(Context_Control, field) == off ## _OFFSET, \
Context_Control_offset_ ## field \
Thread register context.
◆ _CPU_Context_Initialize()
void _CPU_Context_Initialize ( Context_Control *  the_context,
uint32_t *  stack_base,
uint32_t  size,
uint32_t  new_level,
void *  entry_point,
bool  is_fp,
void *  tls_area
Initialize the context to a state suitable for starting a task after a context restore operation. Generally, this involves:
  • setting a starting address
  • preparing the stack
  • preparing the stack and frame pointers
  • setting the proper interrupt level in the context
  • initializing the floating point context
Parameters
[in]the_contextpoints to the context area
[in]stack_baseis the low address of the allocated stack area
[in]sizeis the size of the stack area in bytes
[in]new_levelis the interrupt level for the task
[in]entry_pointis the task's entry point
[in]is_fpis set to TRUE if the task is a floating point task
[in]tls_areais the thread-local storage (TLS) area
NOTE: Implemented as a subroutine for the SPARC port.
Variable Documentation
◆ _CPU_Trap_slot_template
Initial value:
0xa1480000,
0x29000000,
0x81c52000,
0xa6102000
This is the set of opcodes for the instructions loaded into a trap table entry. The routine which installs a handler is responsible for filling in the fields for the _handler address and the _vector trap type.
The constants following this structure are masks for the fields which must be filled in when the handler is installed.
