RTEMS  5.1
irq.h
1 /* irq.h
2  *
3  * This include file describe the data structure and the functions implemented
4  * by RTEMS to write interrupt handlers.
5  *
6  * Copyright (C) 1999 valette@crf.canon.fr
7  *
8  * This code is heavilly inspired by the public specification of STREAM V2
9  * that can be found at :
10  *
11  * <http://www.chorus.com/Documentation/index.html> by following
12  * the STREAM API Specification Document link.
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18
19 #ifndef BSP_POWERPC_IRQ_H
20 #define BSP_POWERPC_IRQ_H
21
22 #define BSP_SHARED_HANDLER_SUPPORT 1
23 #include <rtems/irq.h>
24 #include <bsp/irq-default.h>
25
26 /*
27  * 8259 edge/level control definitions at VIA
28  */
29 #define ISA8259_M_ELCR 0x4d0
30 #define ISA8259_S_ELCR 0x4d1
31
32 #define ELCRS_INT15_LVL 0x80
33 #define ELCRS_INT14_LVL 0x40
34 #define ELCRS_INT13_LVL 0x20
35 #define ELCRS_INT12_LVL 0x10
36 #define ELCRS_INT11_LVL 0x08
37 #define ELCRS_INT10_LVL 0x04
38 #define ELCRS_INT9_LVL 0x02
39 #define ELCRS_INT8_LVL 0x01
40 #define ELCRM_INT7_LVL 0x80
41 #define ELCRM_INT6_LVL 0x40
42 #define ELCRM_INT5_LVL 0x20
43 #define ELCRM_INT4_LVL 0x10
44 #define ELCRM_INT3_LVL 0x8
45 #define ELCRM_INT2_LVL 0x4
46 #define ELCRM_INT1_LVL 0x2
47 #define ELCRM_INT0_LVL 0x1
48
49  /* PIC's command and mask registers */
50 #define PIC_MASTER_COMMAND_IO_PORT 0x20 /* Master PIC command register */
51 #define PIC_SLAVE_COMMAND_IO_PORT 0xa0 /* Slave PIC command register */
52 #define PIC_MASTER_IMR_IO_PORT 0x21 /* Master PIC Interrupt Mask Register */
53 #define PIC_SLAVE_IMR_IO_PORT 0xa1 /* Slave PIC Interrupt Mask Register */
54
55  /* Command for specific EOI (End Of Interrupt): Interrupt acknowledge */
56 #define PIC_EOSI 0x60 /* End of Specific Interrupt (EOSI) */
57 #define SLAVE_PIC_EOSI 0x62 /* End of Specific Interrupt (EOSI) for cascade */
58 #define PIC_EOI 0x20 /* Generic End of Interrupt (EOI) */
59
60 #ifndef ASM
61
62 #ifdef __cplusplus
63 extern "C" {
64 #endif
65
66 /*
67  * rtems_irq_number Definitions
68  */
69
70 /*
71  * ISA IRQ handler related definitions
72  */
73 #define BSP_ISA_IRQ_NUMBER (16)
74 #define BSP_ISA_IRQ_LOWEST_OFFSET (0)
75 #define BSP_ISA_IRQ_MAX_OFFSET (BSP_ISA_IRQ_LOWEST_OFFSET + BSP_ISA_IRQ_NUMBER - 1)
76 /*
77  * PCI IRQ handlers related definitions
78  * CAUTION : BSP_PCI_IRQ_LOWEST_OFFSET should be equal to OPENPIC_VEC_SOURCE
79  */
80 #ifndef qemu
81 #define BSP_PCI_IRQ_NUMBER (16)
82 #else
83 #define BSP_PCI_IRQ_NUMBER (0)
84 #endif
85 #define BSP_PCI_IRQ_LOWEST_OFFSET (BSP_ISA_IRQ_NUMBER)
86 #define BSP_PCI_IRQ_MAX_OFFSET (BSP_PCI_IRQ_LOWEST_OFFSET + BSP_PCI_IRQ_NUMBER - 1)
87 /*
88  * PowerPC exceptions handled as interrupt where an RTEMS managed interrupt
89  * handler might be connected
90  */
91 #define BSP_PROCESSOR_IRQ_NUMBER (1)
92 #define BSP_PROCESSOR_IRQ_LOWEST_OFFSET (BSP_PCI_IRQ_MAX_OFFSET + 1)
93 #define BSP_PROCESSOR_IRQ_MAX_OFFSET (BSP_PROCESSOR_IRQ_LOWEST_OFFSET + BSP_PROCESSOR_IRQ_NUMBER - 1)
94 /* Misc vectors for OPENPIC irqs (IPI, timers)
95  */
96 #ifndef qemu
97 #define BSP_MISC_IRQ_NUMBER (8)
98 #else
99 #define BSP_MISC_IRQ_NUMBER (0)
100 #endif
101
102 #define BSP_MISC_IRQ_LOWEST_OFFSET (BSP_PROCESSOR_IRQ_MAX_OFFSET + 1)
103 #define BSP_MISC_IRQ_MAX_OFFSET (BSP_MISC_IRQ_LOWEST_OFFSET + BSP_MISC_IRQ_NUMBER - 1)
104 /*
105  * Summary
106  */
107 #define BSP_IRQ_NUMBER (BSP_MISC_IRQ_MAX_OFFSET + 1)
108 #define BSP_LOWEST_OFFSET (BSP_ISA_IRQ_LOWEST_OFFSET)
109 #define BSP_MAX_OFFSET (BSP_MISC_IRQ_MAX_OFFSET)
110 /*
111  * Some ISA IRQ symbolic name definition
112  */
113 #define BSP_ISA_PERIODIC_TIMER (0)
114 #define BSP_ISA_KEYBOARD (1)
115 #define BSP_ISA_UART_COM2_IRQ (3)
116 #define BSP_ISA_UART_COM1_IRQ (4)
117 #define BSP_ISA_RT_TIMER1 (8)
118 #define BSP_ISA_RT_TIMER3 (10)
119 /*
120  * Some PCI IRQ symbolic name definition
121  */
122 #define BSP_PCI_IRQ0 (BSP_PCI_IRQ_LOWEST_OFFSET)
123 #if BSP_PCI_IRQ_NUMBER > 0
124 #define BSP_PCI_ISA_BRIDGE_IRQ (BSP_PCI_IRQ0)
125 #endif
126
127 #if defined(mvme2100)
128 #define BSP_DEC21143_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 1)
129 #define BSP_PMC_PCMIP_TYPE1_SLOT0_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 2)
130 #define BSP_PCMIP_TYPE1_SLOT1_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 3)
131 #define BSP_PCMIP_TYPE2_SLOT0_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 4)
132 #define BSP_PCMIP_TYPE2_SLOT1_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 5)
133 #define BSP_PCI_INTA_UNIVERSE_LINT0_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 7)
134 #define BSP_PCI_INTB_UNIVERSE_LINT1_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 8)
135 #define BSP_PCI_INTC_UNIVERSE_LINT2_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 9)
136 #define BSP_PCI_INTD_UNIVERSE_LINT3_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 10)
137 #define BSP_UART_COM1_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 13)
138 #define BSP_FRONT_PANEL_ABORT_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 14)
139 #define BSP_RTC_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 15)
140 #else
141 #define BSP_UART_COM1_IRQ BSP_ISA_UART_COM1_IRQ
142 #define BSP_UART_COM2_IRQ BSP_ISA_UART_COM2_IRQ
143 #endif
144
145 /*
146  * Some Processor execption handled as RTEMS IRQ symbolic name definition
147  */
148 #define BSP_DECREMENTER (BSP_PROCESSOR_IRQ_LOWEST_OFFSET)
149
150
151 /*
152  * Type definition for RTEMS managed interrupts
153  */
154 typedef unsigned short rtems_i8259_masks;
155
156 extern volatile rtems_i8259_masks i8259s_cache;
157
158 /*-------------------------------------------------------------------------+
159 | Function Prototypes.
160 +--------------------------------------------------------------------------*/
161 /*
162  * ------------------------ Intel 8259 (or emulation) Mngt Routines -------
163  */
164 void BSP_i8259s_init(void);
165
166 /*
167  * function to disable a particular irq at 8259 level. After calling
168  * this function, even if the device asserts the interrupt line it will
169  * not be propagated further to the processor
170  *
171  * RETURNS: 1/0 if the interrupt was enabled/disabled originally or
172  * a value < 0 on error.
173  */
174 int BSP_irq_disable_at_i8259s (const rtems_irq_number irqLine);
175 /*
176  * function to enable a particular irq at 8259 level. After calling
177  * this function, if the device asserts the interrupt line it will
178  * be propagated further to the processor
179  */
180 int BSP_irq_enable_at_i8259s (const rtems_irq_number irqLine);
181 /*
182  * function to acknowledge a particular irq at 8259 level. After calling
183  * this function, if a device asserts an enabled interrupt line it will
184  * be propagated further to the processor. Mainly usefull for people
185  * writing raw handlers as this is automagically done for RTEMS managed
186  * handlers.
187  */
188 int BSP_irq_ack_at_i8259s (const rtems_irq_number irqLine);
189 /*
190  * function to check if a particular irq is enabled at 8259 level. After calling
191  */
192 int BSP_irq_enabled_at_i8259s (const rtems_irq_number irqLine);
193
194 extern void BSP_rtems_irq_mng_init(unsigned cpuId);
195 extern void BSP_i8259s_init(void);
196
197 /* Stuff in irq_supp.h should eventually go into <rtems/irq.h> */
198 #include <bsp/irq_supp.h>
199
200 #ifdef __cplusplus
201 };
202 #endif
203
204 #endif
205 #endif
Type definition for RTEMS managed interrupts.
Definition: irq.h:88
int BSP_irq_enable_at_i8259s(const rtems_irq_number irqLine)
Definition: i8259.c:91
int BSP_irq_enabled_at_i8259s(const rtems_irq_number irqLine)
Definition: i8259.c:125
int BSP_irq_ack_at_i8259s(const rtems_irq_number irqLine)
Definition: i8259.c:143
int BSP_irq_disable_at_i8259s(const rtems_irq_number irqLine)
Definition: i8259.c:49
