22 #ifndef LIBBSP_M68K_UC5282_BSP_H    23 #define LIBBSP_M68K_UC5282_BSP_H    51 #define RTEMS_MCF5282_BSP_ENABLE_DATA_CACHE    55 #include <mcf5282/mcf5282.h>       59 struct rtems_bsdnet_ifconfig;
    60 extern int rtems_fec_driver_attach (
struct rtems_bsdnet_ifconfig *
config,
int attaching );
    61 #define RTEMS_BSP_NETWORK_DRIVER_NAME     "fs1"    62 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_fec_driver_attach    68 #define CONSOLE_PORT        0    77 #define RTEMS_BSP_PGM_ERASE_FIRST   0x1    78 #define RTEMS_BSP_PGM_RESET_AFTER   0x2    79 #define RTEMS_BSP_PGM_EXEC_AFTER    0x4    80 #define RTEMS_BSP_PGM_HALT_AFTER    0x8    82 uint32_t bsp_get_CPU_clock_speed(
void);
    84 int bsp_sysReset(
int flags);
    86 unsigned const char *bsp_gethwaddr(
int a);
    87 const char *bsp_getbenv(
const char *a);
    88 int bsp_flash_erase_range(
volatile unsigned short *flashptr,
int start,
int end);
    89 int bsp_flash_write_range(
bsp_mnode_t *chain,
int offset);
    92   rtems_isr_entry     handler,
   101 #define FEC_IRQ_LEVEL       4   102 #define FEC_IRQ_RX_PRIORITY 7   103 #define FEC_IRQ_TX_PRIORITY 6   105 #define PIT3_IRQ_LEVEL      4   106 #define PIT3_IRQ_PRIORITY   0   108 #define UART0_IRQ_LEVEL     3   109 #define UART0_IRQ_PRIORITY  7   110 #define UART1_IRQ_LEVEL     3   111 #define UART1_IRQ_PRIORITY  6   112 #define UART2_IRQ_LEVEL     3   113 #define UART2_IRQ_PRIORITY  5   119 #define VME_AM_STD_SUP_ASCENDING   0x3f   120 #define VME_AM_STD_SUP_PGM         0x3e   121 #define VME_AM_STD_USR_ASCENDING   0x3b   122 #define VME_AM_STD_USR_PGM         0x3a   123 #define VME_AM_STD_SUP_DATA        0x3d   124 #define VME_AM_STD_USR_DATA        0x39   125 #define VME_AM_EXT_SUP_ASCENDING   0x0f   126 #define VME_AM_EXT_SUP_PGM         0x0e   127 #define VME_AM_EXT_USR_ASCENDING   0x0b   128 #define VME_AM_EXT_USR_PGM         0x0a   129 #define VME_AM_EXT_SUP_DATA        0x0d   130 #define VME_AM_EXT_USR_DATA        0x09   131 #define VME_AM_SUP_SHORT_IO        0x2d   132 #define VME_AM_USR_SHORT_IO        0x29   138 typedef void (*BSP_VME_ISR_t)(
void *usrArg,
unsigned long vector);
   139 BSP_VME_ISR_t BSP_getVME_isr(
unsigned long vector,
void **parg);
   140 int BSP_installVME_isr(
unsigned long vector, BSP_VME_ISR_t handler,
void *usrArg);
   141 int BSP_removeVME_isr(
void *usrArg);
   142 int BSP_enableVME_int_lvl(
unsigned int level);
   143 int BSP_disableVME_int_lvl(
   144 int BSP_vme2local_adrs(
unsigned am,
unsigned long vmeaddr,
unsigned long *plocaladdr);
   152 #define BSP_IDLE_TASK_BODY bsp_idle_thread   157 int bsp_cpu_load_percentage(
void);
   162 void bsp_reset_cause(
char *buf,
size_t capacity);
   171     volatile uint16_t   status;
   173     volatile void      *buffer;
   177     uint32_t                  idle_counter;
   178     uint32_t                  filtered_idle;
   179     uint32_t                  max_idle_count;
   180     uint32_t                  pitc_per_tick;
   181     uint32_t                  nsec_per_pitc;
 Definition: deflate.c:115
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
rtems_status_code
Classic API Status.
Definition: status.h:43
Interface to Kernel Print Methods.
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition: bspidle.c:26
unsigned l
Definition: tte.h:86
unsigned v
Definition: tte.h:73
