RTEMS  5.1
Global BSP definitions. More...
#include <bspopts.h>
#include <bsp/default-initial-extension.h>
#include <rtems/bspIo.h>
#include <mcf5282/mcf5282.h>
struct  bsp_mnode_t
struct  mcf5282BufferDescriptor_
#define RTEMS_MCF5282_BSP_ENABLE_DATA_CACHE
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "fs1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_fec_driver_attach
#define CONSOLE_PORT   0
#define RTEMS_BSP_PGM_ERASE_FIRST   0x1
#define RTEMS_BSP_PGM_RESET_AFTER   0x2
#define RTEMS_BSP_PGM_EXEC_AFTER   0x4
#define RTEMS_BSP_PGM_HALT_AFTER   0x8
#define FEC_IRQ_LEVEL   4
#define FEC_IRQ_RX_PRIORITY   7
#define FEC_IRQ_TX_PRIORITY   6
#define PIT3_IRQ_LEVEL   4
#define PIT3_IRQ_PRIORITY   0
#define UART0_IRQ_LEVEL   3
#define UART0_IRQ_PRIORITY   7
#define UART1_IRQ_LEVEL   3
#define UART1_IRQ_PRIORITY   6
#define UART2_IRQ_LEVEL   3
#define UART2_IRQ_PRIORITY   5
#define VME_AM_STD_SUP_ASCENDING   0x3f
#define VME_AM_STD_SUP_PGM   0x3e
#define VME_AM_STD_USR_ASCENDING   0x3b
#define VME_AM_STD_USR_PGM   0x3a
#define VME_AM_STD_SUP_DATA   0x3d
#define VME_AM_STD_USR_DATA   0x39
#define VME_AM_EXT_SUP_ASCENDING   0x0f
#define VME_AM_EXT_SUP_PGM   0x0e
#define VME_AM_EXT_USR_ASCENDING   0x0b
#define VME_AM_EXT_USR_PGM   0x0a
#define VME_AM_EXT_SUP_DATA   0x0d
#define VME_AM_EXT_USR_DATA   0x09
#define VME_AM_SUP_SHORT_IO   0x2d
#define VME_AM_USR_SHORT_IO   0x29
#define BSP_IDLE_TASK_BODY   bsp_idle_thread
typedef void(* BSP_VME_ISR_t) (void *usrArg, unsigned long vector)
typedef struct mcf5282BufferDescriptor_ mcf5282BufferDescriptor_t
int rtems_fec_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching)
uint32_t bsp_get_CPU_clock_speed (void)
rtems_status_code bsp_allocate_interrupt (int level, int priority)
int bsp_sysReset (int flags)
int bsp_program (bsp_mnode_t *chain, int flags)
unsigned const char * bsp_gethwaddr (int a)
const char * bsp_getbenv (const char *a)
int bsp_flash_erase_range (volatile unsigned short *flashptr, int start, int end)
int bsp_flash_write_range (volatile unsigned short *flashptr, bsp_mnode_t *chain, int offset)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler. More...
rtems_status_code bspExtInit (void)
BSP_VME_ISR_t BSP_getVME_isr (unsigned long vector, void **parg)
int BSP_installVME_isr (unsigned long vector, BSP_VME_ISR_t handler, void *usrArg)
int BSP_removeVME_isr (unsigned long vector, BSP_VME_ISR_t handler, void *usrArg)
int BSP_enableVME_int_lvl (unsigned int level)
int BSP_disableVME_int_lvl (unsigned int level)
int BSP_vme2local_adrs (unsigned am, unsigned long vmeaddr, unsigned long *plocaladdr)
void * bsp_idle_thread (uintptr_t ignored)
 Optimized idle task. More...
int bsp_cpu_load_percentage (void)
void bsp_reset_cause (char *buf, size_t capacity)
struct {
   uint32_t   idle_counter
   uint32_t   filtered_idle
   uint32_t   max_idle_count
   uint32_t   pitc_per_tick
   uint32_t   nsec_per_pitc
   uint32_t   pad [3]
   mcf5282BufferDescriptor_t   fec_descriptors []
} __SRAMBASE
