25 #ifndef LIBBSP_M68K_MVME147S_BSP_H    26 #define LIBBSP_M68K_MVME147S_BSP_H    49 #define RAM_START 0x00007000    50 #define RAM_END   0x003e0000    51 #define DRAM_END  0x00400000    59   uint32_t         dma_table_address;
    60   uint32_t         dma_data_address;
    61   uint32_t         dma_bytecount;
    62   uint32_t         dma_data_holding;
    65   uint16_t         timer1_preload;
    66   uint16_t         timer1_count;
    67   uint16_t         timer2_preload;
    68   uint16_t         timer2_count;
    71   uint8_t         timer1_int_control;
    72   uint8_t         timer1_control;
    73   uint8_t         timer2_int_control;
    74   uint8_t         timer2_control;
    76   uint8_t         acfail_int_control;
    77   uint8_t         watchdog_control;
    79   uint8_t         printer_int_control;
    80   uint8_t         printer_control;
    82   uint8_t         dma_int_control;
    84   uint8_t         bus_error_int_control;
    86   uint8_t         abort_int_control;
    87   uint8_t         table_address_function_code;
    88   uint8_t         serial_port_int_control;
    89   uint8_t         general_purpose_control;
    90   uint8_t         lan_int_control;
    91   uint8_t         general_purpose_status;
    92   uint8_t         scsi_port_int_control;
    93   uint8_t         slave_base_address;
    94   uint8_t         software_int_1_control;
    95   uint8_t         int_base_vector;
    96   uint8_t         software_int_2_control;
    97   uint8_t         revision_level;
   100 #define pcc      ((volatile struct pcc_map * const) 0xfffe1000)   106   uint8_t         system_controller;
   108   uint8_t         vme_bus_requester;
   110   uint8_t         master_configuration;
   112   uint8_t         slave_configuration;
   114   uint8_t         timer_configuration;
   116   uint8_t         slave_address_modifier;
   118   uint8_t         master_address_modifier;
   120   uint8_t         interrupt_handler_mask;
   122   uint8_t         utility_interrupt_mask;
   124   uint8_t         utility_interrupt_vector;
   126   uint8_t         interrupt_request;
   128   uint8_t         vme_bus_status_id;
   130   uint8_t         bus_error_status;
   132   uint8_t         gcsr_base_address;
   135 #define vme_lcsr      ((volatile struct vme_lcsr_map * const) 0xfffe2000)   143   uint8_t         board_identification;
   145   uint8_t         general_purpose_0;
   147   uint8_t         general_purpose_1;
   149   uint8_t         general_purpose_2;
   151   uint8_t         general_purpose_3;
   153   uint8_t         general_purpose_4;
   156 #define vme_gcsr      ((volatile struct vme_gcsr_map * const) 0xfffe2020)   158 #define z8530 0xfffe3001   161 #define PCC_BASE_VECTOR        0x40    162 #define SCC_VECTOR             PCC_BASE_VECTOR+3   163 #define TIMER_1_VECTOR         PCC_BASE_VECTOR+8   164 #define TIMER_2_VECTOR         PCC_BASE_VECTOR+9   165 #define SOFT_1_VECTOR          PCC_BASE_VECTOR+10   166 #define SOFT_2_VECTOR          PCC_BASE_VECTOR+11   168 #define VME_BASE_VECTOR        0x50   169 #define VME_SIGLP_VECTOR       VME_BASE_VECTOR+1   171 #define USE_CHANNEL_A   1                   172 #define USE_CHANNEL_B   0                   174 #if (USE_CHANNEL_A == 1)   175 #define CONSOLE_CONTROL  0xfffe3002   176 #define CONSOLE_DATA     0xfffe3003   177 #elif (USE_CHANNEL_B == 1)   178 #define CONSOLE_CONTROL  0xfffe3000   179 #define CONSOLE_DATA     0xfffe3001   189 #define EXTERN extern   192 extern rtems_isr_entry M68Kvec[];
   201   rtems_isr_entry     handler,
 rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
