Global BSP definitions.
More...
#include <bspopts.h>
#include <bsp/default-initial-extension.h>
#define  | RAM_START   0x00007000 |
#define  | RAM_END   0x003e0000 |
#define  | DRAM_END   0x00400000 |
#define  | pcc   ((volatile struct pcc_map * const) 0xfffe1000) |
#define  | vme_lcsr   ((volatile struct vme_lcsr_map * const) 0xfffe2000) |
#define  | vme_gcsr   ((volatile struct vme_gcsr_map * const) 0xfffe2020) |
#define  | z8530   0xfffe3001 |
#define  | PCC_BASE_VECTOR   0x40 /* First user int */ |
#define  | SCC_VECTOR   PCC_BASE_VECTOR+3 |
#define  | TIMER_1_VECTOR   PCC_BASE_VECTOR+8 |
#define  | TIMER_2_VECTOR   PCC_BASE_VECTOR+9 |
#define  | SOFT_1_VECTOR   PCC_BASE_VECTOR+10 |
#define  | SOFT_2_VECTOR   PCC_BASE_VECTOR+11 |
#define  | VME_BASE_VECTOR   0x50 |
#define  | VME_SIGLP_VECTOR   VME_BASE_VECTOR+1 |
#define  | USE_CHANNEL_A   1                /* 1 = use channel A for console */ |
#define  | USE_CHANNEL_B   0                /* 1 = use channel B for console */ |
#define  | CONSOLE_CONTROL   0xfffe3002 |
#define  | CONSOLE_DATA   0xfffe3003 |
#define  | FOREVER   1                  /* infinite loop */ |
#define  | EXTERN   extern |
rtems_isr_entry  | M68Kvec [] |
