RTEMS  5.1
bsp.h
1
10 /*
11  * mcf52235 BSP header file
12  */
13
14 #ifndef LIBBSP_M68K_MCF5329_BSP_H
15 #define LIBBSP_M68K_MCF5329_BSP_H
16
27 #include <bspopts.h>
29 #include <rtems.h>
30 #include <rtems/bspIo.h>
31
32 /***************************************************************************/
34 #include <mcf532x/mcf532x.h>
35
36 #ifdef __cplusplus
37 extern "C" {
38 #endif
39
40 typedef volatile unsigned char vuint8;
41 typedef volatile unsigned short vuint16;
42 typedef volatile unsigned long vuint32;
43
44 /***************************************************************************/
46 struct rtems_bsdnet_ifconfig;
47 extern int rtems_fec_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching );
48 #define RTEMS_BSP_NETWORK_DRIVER_NAME "fec0"
49 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_fec_driver_attach
50
51 /***************************************************************************/
54 /* define which port the console should use - all other ports are then defined as general purpose */
55 #define CONSOLE_PORT 0
56
57 /* functions */
58
59 uint32_t bsp_get_CPU_clock_speed(void);
60 uint32_t bsp_get_BUS_clock_speed(void);
61
62 rtems_isr_entry set_vector(
63  rtems_isr_entry handler,
64  rtems_vector_number vector,
65  int type
66 );
67
68 /*
69  * Interrupt assignments
70  * Highest-priority listed first
71  */
72 #define FEC_IRQ_LEVEL 4
73
74 #define PIT3_IRQ_LEVEL 4
75
76 #define UART0_IRQ_LEVEL 3
77 #define UART1_IRQ_LEVEL 3
78 #define UART2_IRQ_LEVEL 3
79
80 /*
81  * Prototypes for BSP methods which cross file boundaries
82  */
83 void Init5329(void);
84
85 #ifdef __cplusplus
86 }
87 #endif
88
91 #endif
Definition: deflate.c:115
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Interface to Kernel Print Methods.
Definition: bsp.h:40
