    RTEMS
    5.1
Global BSP definitions. More...
#include <bspopts.h>#include <bsp/default-initial-extension.h>#include <rtems.h>#include <rtems/bspIo.h>#include <mcf532x/mcf532x.h>Go to the source code of this file.
| #define | RTEMS_BSP_NETWORK_DRIVER_NAME "fec0" |
| #define | RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_fec_driver_attach |
| #define | CONSOLE_PORT 0 |
| #define | FEC_IRQ_LEVEL 4 |
| #define | PIT3_IRQ_LEVEL 4 |
| #define | UART0_IRQ_LEVEL 3 |
| #define | UART1_IRQ_LEVEL 3 |
| #define | UART2_IRQ_LEVEL 3 |
Typedefs | |
| typedef volatile unsigned char | vuint8 |
| typedef volatile unsigned short | vuint16 |
| typedef volatile unsigned long | vuint32 |
| int | rtems_fec_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching) |
| uint32_t | bsp_get_CPU_clock_speed (void) |
| uint32_t | bsp_get_BUS_clock_speed (void) |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| Install an interrupt handler.  More... | |
| void | Init5329 (void) |
 1.8.15
