26 #ifndef LIBBSP_M68K_CSB360_BSP_H    27 #define LIBBSP_M68K_CSB360_BSP_H    39 #include <mcf5272/mcf5272.h>    42 #define BSP_MEM_ADDR_SRAM 0x20000000    43 #define BSP_MEM_SIZE_SRAM 4096    48 #define BSP_MEM_ADDR_SDRAM 0x00000000    49 #define BSP_MEM_MASK_SDRAM 0x01ffffff    50 #define BSP_MEM_SIZE_SDRAM (32 * 1024 * 1024)    53 #define BSP_MBAR 0x10000000    56 #define BSP_RAMBAR BSP_MEM_ADDR_SRAM    59 #define BSP_INTVEC_INT1   65    60 #define BSP_INTVEC_INT2   66    61 #define BSP_INTVEC_INT3   67    62 #define BSP_INTVEC_INT4   68    63 #define BSP_INTVEC_TMR0   69    64 #define BSP_INTVEC_TMR1   70    65 #define BSP_INTVEC_TMR2   71    66 #define BSP_INTVEC_TMR3   72    67 #define BSP_INTVEC_UART1  73    68 #define BSP_INTVEC_UART2  74    69 #define BSP_INTVEC_PLIP   75    70 #define BSP_INTVEC_PLIA   76    71 #define BSP_INTVEC_USB0   77    72 #define BSP_INTVEC_USB1   78    73 #define BSP_INTVEC_USB2   79    74 #define BSP_INTVEC_USB3   80    75 #define BSP_INTVEC_USB4   81    76 #define BSP_INTVEC_USB5   82    77 #define BSP_INTVEC_USB6   83    78 #define BSP_INTVEC_USB7   84    79 #define BSP_INTVEC_DMA    85    80 #define BSP_INTVEC_ERX    86    81 #define BSP_INTVEC_ETX    87    82 #define BSP_INTVEC_ENTC   88    83 #define BSP_INTVEC_QSPI   89    84 #define BSP_INTVEC_INT5   90    85 #define BSP_INTVEC_INT6   91    86 #define BSP_INTVEC_SWTO   92    88 #define BSP_INTLVL_INT1   1    89 #define BSP_INTLVL_INT2   1    90 #define BSP_INTLVL_INT3   1    91 #define BSP_INTLVL_INT4   1    92 #define BSP_INTLVL_TMR0   1    93 #define BSP_INTLVL_TMR1   1    94 #define BSP_INTLVL_TMR2   1    95 #define BSP_INTLVL_TMR3   1    96 #define BSP_INTLVL_UART1  1    97 #define BSP_INTLVL_UART2  1    98 #define BSP_INTLVL_PLIP   1    99 #define BSP_INTLVL_PLIA   1   100 #define BSP_INTLVL_USB0   1   101 #define BSP_INTLVL_USB1   1   102 #define BSP_INTLVL_USB2   1   103 #define BSP_INTLVL_USB3   1   104 #define BSP_INTLVL_USB4   1   105 #define BSP_INTLVL_USB5   1   106 #define BSP_INTLVL_USB6   1   107 #define BSP_INTLVL_USB7   1   108 #define BSP_INTLVL_DMA    1   109 #define BSP_INTLVL_ERX    1   110 #define BSP_INTLVL_ETX    1   111 #define BSP_INTLVL_ENTC   1   112 #define BSP_INTLVL_QSPI   1   113 #define BSP_INTLVL_INT5   1   114 #define BSP_INTLVL_INT6   1   115 #define BSP_INTLVL_SWTO   1   129 struct rtems_bsdnet_ifconfig;
   130 extern int rtems_enet_driver_attach (
struct rtems_bsdnet_ifconfig *
config);
   131 #define RTEMS_BSP_NETWORK_DRIVER_NAME   "eth0"   132 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_enet_driver_attach   135 #define BSP_SYSTEM_FREQUENCY (66 * 1000 * 1000)   142 #define rtems_bsp_delay( microseconds ) \   143   { register uint32_t _delay=(microseconds); \   144     register uint32_t _tmp=123; \   145     __asm__ volatile( "0: \   149                   : "=d" (_tmp), "=d" (_delay) \   150                   : "0"  (_tmp), "1"  (_delay) ); \   157 #define RTC_DRIVER_TABLE_ENTRY \   158     { rtc_initialize, NULL, NULL, NULL, NULL, NULL }   160     rtems_device_major_number major,
   161     rtems_device_minor_number minor,
   167 extern rtems_isr_entry M68Kvec[];
   174   rtems_isr_entry     handler,
 Definition: deflate.c:115
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
ISR_Handler rtems_isr
Return type for interrupt handler.
Definition: intr.h:52
rtems_status_code
Classic API Status.
Definition: status.h:43
rtems_device_driver rtc_initialize(rtems_device_major_number major, rtems_device_minor_number minor_arg, void *arg)
Definition: rtc.c:160
