CSB3602 Board Support Package.
More...
| file   | bsp.h |
|   | Global BSP definitions.
#define  | BSP_MEM_ADDR_SRAM   0x20000000 |
#define  | BSP_MEM_SIZE_SRAM   4096 |
#define  | BSP_MEM_ADDR_SDRAM   0x00000000 |
#define  | BSP_MEM_MASK_SDRAM   0x01ffffff |
#define  | BSP_MEM_SIZE_SDRAM   (32 * 1024 * 1024) |
#define  | BSP_MBAR   0x10000000 |
#define  | BSP_RAMBAR   BSP_MEM_ADDR_SRAM |
#define  | BSP_INTVEC_INT1   65 |
#define  | BSP_INTVEC_INT2   66 |
#define  | BSP_INTVEC_INT3   67 |
#define  | BSP_INTVEC_INT4   68 |
#define  | BSP_INTVEC_TMR0   69 |
#define  | BSP_INTVEC_TMR1   70 |
#define  | BSP_INTVEC_TMR2   71 |
#define  | BSP_INTVEC_TMR3   72 |
#define  | BSP_INTVEC_UART1   73 |
#define  | BSP_INTVEC_UART2   74 |
#define  | BSP_INTVEC_PLIP   75 |
#define  | BSP_INTVEC_PLIA   76 |
#define  | BSP_INTVEC_USB0   77 |
#define  | BSP_INTVEC_USB1   78 |
#define  | BSP_INTVEC_USB2   79 |
#define  | BSP_INTVEC_USB3   80 |
#define  | BSP_INTVEC_USB4   81 |
#define  | BSP_INTVEC_USB5   82 |
#define  | BSP_INTVEC_USB6   83 |
#define  | BSP_INTVEC_USB7   84 |
#define  | BSP_INTVEC_DMA   85 |
#define  | BSP_INTVEC_ERX   86 |
#define  | BSP_INTVEC_ETX   87 |
#define  | BSP_INTVEC_ENTC   88 |
#define  | BSP_INTVEC_QSPI   89 |
#define  | BSP_INTVEC_INT5   90 |
#define  | BSP_INTVEC_INT6   91 |
#define  | BSP_INTVEC_SWTO   92 |
#define  | BSP_INTLVL_INT1   1 |
#define  | BSP_INTLVL_INT2   1 |
#define  | BSP_INTLVL_INT3   1 |
#define  | BSP_INTLVL_INT4   1 |
#define  | BSP_INTLVL_TMR0   1 |
#define  | BSP_INTLVL_TMR1   1 |
#define  | BSP_INTLVL_TMR2   1 |
#define  | BSP_INTLVL_TMR3   1 |
#define  | BSP_INTLVL_UART1   1 |
#define  | BSP_INTLVL_UART2   1 |
#define  | BSP_INTLVL_PLIP   1 |
#define  | BSP_INTLVL_PLIA   1 |
#define  | BSP_INTLVL_USB0   1 |
#define  | BSP_INTLVL_USB1   1 |
#define  | BSP_INTLVL_USB2   1 |
#define  | BSP_INTLVL_USB3   1 |
#define  | BSP_INTLVL_USB4   1 |
#define  | BSP_INTLVL_USB5   1 |
#define  | BSP_INTLVL_USB6   1 |
#define  | BSP_INTLVL_USB7   1 |
#define  | BSP_INTLVL_DMA   1 |
#define  | BSP_INTLVL_ERX   1 |
#define  | BSP_INTLVL_ETX   1 |
#define  | BSP_INTLVL_ENTC   1 |
#define  | BSP_INTLVL_QSPI   1 |
#define  | BSP_INTLVL_INT5   1 |
#define  | BSP_INTLVL_INT6   1 |
#define  | BSP_INTLVL_SWTO   1 |
#define  | RTEMS_BSP_NETWORK_DRIVER_NAME   "eth0" |
#define  | RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_enet_driver_attach |
#define  | BSP_SYSTEM_FREQUENCY   (66 * 1000 * 1000) |
| #define  | rtems_bsp_delay(microseconds) |
#define  | RTC_DRIVER_TABLE_ENTRY   { rtc_initialize, NULL, NULL, NULL, NULL, NULL } |
int  | rtems_enet_driver_attach (struct rtems_bsdnet_ifconfig *config) |
rtems_device_driver  | rtc_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| rtems_isr_entry  | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
|   | Install an interrupt handler.  More...
void  | init5272 (void) |
◆ rtems_bsp_delay
          | #define rtems_bsp_delay |
          microseconds | ) |
Value:{ register uint32_t _delay=(microseconds); \
    register uint32_t _tmp=123; \
    __asm__ volatile( "0: \                     nbcd      %0 ; \                     nbcd      %0 ; \                     dbf       %1,0b" \
                  : "=d" (_tmp), "=d" (_delay) \
                  : "0"  (_tmp), "1"  (_delay) ); \
◆ set_vector()
This method installs an interrupt handle.
- Parameters
    | [in] | handler | is the isr routine  |
    | [in] | vector | is the vector number  |
    | [in] | type | indicates whether RTEMS or RAW intr |
- Returns
 - returns old vector
