13 #ifndef LIBBSP_M68K_AV5282_BSP_H    14 #define LIBBSP_M68K_AV5282_BSP_H    36 #include <mcf5282/mcf5282.h>       44 struct rtems_bsdnet_ifconfig;
    45 extern int rtems_fec_driver_attach (
struct rtems_bsdnet_ifconfig *
config,
int attaching );
    46 #define RTEMS_BSP_NETWORK_DRIVER_NAME     "fs1"    47 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_fec_driver_attach    53 #define CONSOLE_PORT        0    63 uint32_t get_CPU_clock_speed(
void);
    66   rtems_isr_entry     handler,
    75 #define FEC_IRQ_LEVEL       4    76 #define FEC_IRQ_RX_PRIORITY 7    77 #define FEC_IRQ_TX_PRIORITY 6    79 #define PIT3_IRQ_LEVEL      4    80 #define PIT3_IRQ_PRIORITY   0    82 #define UART0_IRQ_LEVEL     3    83 #define UART0_IRQ_PRIORITY  7    84 #define UART1_IRQ_LEVEL     3    85 #define UART1_IRQ_PRIORITY  6    86 #define UART2_IRQ_LEVEL     3    87 #define UART2_IRQ_PRIORITY  5 Definition: deflate.c:115
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Interface to Kernel Print Methods.
