AV5282 Board Support Package.
More...
| file   | bsp.h |
|   | Global BSP definitions.
#define  | RTEMS_BSP_NETWORK_DRIVER_NAME   "fs1" |
#define  | RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_fec_driver_attach |
| #define  | CONSOLE_PORT   0 |
#define  | FEC_IRQ_LEVEL   4 |
#define  | FEC_IRQ_RX_PRIORITY   7 |
#define  | FEC_IRQ_TX_PRIORITY   6 |
#define  | PIT3_IRQ_LEVEL   4 |
#define  | PIT3_IRQ_PRIORITY   0 |
#define  | UART0_IRQ_LEVEL   3 |
#define  | UART0_IRQ_PRIORITY   7 |
#define  | UART1_IRQ_LEVEL   3 |
#define  | UART1_IRQ_PRIORITY   6 |
#define  | UART2_IRQ_LEVEL   3 |
#define  | UART2_IRQ_PRIORITY   5 |
int  | rtems_fec_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching) |
uint32_t  | get_CPU_clock_speed (void) |
| rtems_isr_entry  | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
|   | Install an interrupt handler.  More...
void  | Init5282 (void) |
◆ CONSOLE_PORT
User Definable configuration
◆ set_vector()
This method installs an interrupt handle.
- Parameters
    | [in] | handler | is the isr routine  |
    | [in] | vector | is the vector number  |
    | [in] | type | indicates whether RTEMS or RAW intr |
- Returns
 - returns old vector
