RTEMS  5.1
bsp.h
1
11 /*
12  * COPYRIGHT (c) 2010 by ECE Northeastern University.
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license
17  */
18
19 #ifndef LIBBSP_BFIN_TLL6527M_BSP_H
20 #define LIBBSP_BFIN_TLL6527M_BSP_H
21
32 #ifndef ASM
33
34 #include <bspopts.h>
36
37 #include <rtems.h>
38 #include <rtems/score/bfin.h>
39 #include <rtems/bfin/bf52x.h>
40 #include <bf52x.h>
41
42 #ifdef __cplusplus
43 extern "C" {
44 #endif
45
46 /*
47  * PLL and clock setup values:
48  */
49
50 /*
51  * PLL configuration for TLL6527M
52  *
53  * XTL = 27 MHz
54  * CLKIN = 13 MHz
55  * VCO = 391 MHz
56  * CCLK = 391 MHz
57  * SCLK = 130 MHz
58  */
59
65 #define PLL_CSEL 0x0000
66 #define PLL_SSEL 0x0003
67 #define PLL_MSEL 0x3A00
68 #define PLL_DF 0x0001
69
70
77 #define CLKIN (25000000)
78 #define CCLK (600000000)
79 #define SCLK (100000000)
80
81
88 #define BAUDRATE 57600
89 #define WORD_5BITS 0x00
90 #define WORD_6BITS 0x01
91 #define WORD_7BITS 0x02
92 #define WORD_8BITS 0x03
93 #define EVEN_PARITY 0x18
94 #define ODD_PARITY 0x08
95 #define TWO_STP_BIT 0x04
96
97
110 rtems_isr_entry set_vector(
111  rtems_isr_entry handler,
112  rtems_vector_number vector,
113  int type
114 );
115
116 /*
117  * Internal BSP methods that are used across file boundaries
118  */
119 void Init_RTC(void);
120
121 /*
122  * Prototype for methods in .S files that are referenced from C.
123  */
124 void bfin_null_isr(void);
125
126 #ifdef __cplusplus
127 }
128 #endif
129
130 #endif /* !ASM */
131
134 #endif
Basic MMR for the Blackfin 52x CPU.
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
Blackfin Set up Basic CPU Dependency Settings Based on Compiler Settings.
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
