    RTEMS
    5.1
TLL6527M Board Support Package. More...
Modules | |
| CPLB Configuration | |
| CPLB Configuration.  | |
| TM27 Test Support | |
| Interrupt Mechanisms for TM27.  | |
Files | |
| file | bsp.h |
| Global BSP definitions.  | |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| Install an interrupt handler.  More... | |
| void | Init_RTC (void) |
| void | bfin_null_isr (void) |
PLL Configuration | |
| #define | PLL_CSEL 0x0000 |
| CCLK = VCO */.  | |
| #define | PLL_SSEL 0x0003 |
| SCLK = CCLK/3 */.  | |
| #define | PLL_MSEL 0x3A00 |
| VCO = 29xCLKIN */.  | |
| #define | PLL_DF 0x0001 |
| CLKIN = XTL/2 */.  | |
Clock setup values | |
| #define | CLKIN (25000000) |
| Input clock to the PLL */.  | |
| #define | CCLK (600000000) |
| CORE CLOCK */.  | |
| #define | SCLK (100000000) |
| SYSTEM CLOCK */.  | |
UART setup values | |
| #define | BAUDRATE 57600 |
| Console Baudrate */.  | |
| #define | WORD_5BITS 0x00 |
| 5 bits word */  | |
| #define | WORD_6BITS 0x01 |
| 6 bits word */  | |
| #define | WORD_7BITS 0x02 |
| 7 bits word */  | |
| #define | WORD_8BITS 0x03 |
| 8 bits word */  | |
| #define | EVEN_PARITY 0x18 |
| Enable EVEN parity */.  | |
| #define | ODD_PARITY 0x08 |
| Enable ODD parity */.  | |
| #define | TWO_STP_BIT 0x04 |
| 2 stop bits */  | |
| rtems_isr_entry set_vector | ( | rtems_isr_entry | handler, |
| rtems_vector_number | vector, | ||
| int | type | ||
This method installs an interrupt handle.
| [in] | handler | is the isr routine |
| [in] | vector | is the vector number |
| [in] | type | indicates whether RTEMS or RAW intr |
 1.8.15
