RTEMS
5.1
Raspberry Pi specific I2C definitions. More...
#include <dev/i2c/i2c.h>
I2C constants. | |
#define | BSC_CORE_CLK_HZ 150000000 |
BSC controller core clock rate in Hz. More... | |
#define | DEFAULT_BUS_CLOCK 100000 |
Default bus clock. More... | |
I2C directives. | |
void | rpi_i2c_init (void) |
Setups the Raspberry Pi GPIO header to activate the BSC I2C bus. | |
int | rpi_i2c_register_bus (const char *bus_path, uint32_t bus_clock) |
Registers the Raspberry Pi BSC I2C bus with the Linux I2C User-Space API. More... | |
#define BSC_CORE_CLK_HZ 150000000 |
This is set to 150 MHz as per the BCM2835 datasheet.
#define DEFAULT_BUS_CLOCK 100000 |
Default bus clock.
This sets the bus with a 100 kHz clock speed.
int rpi_i2c_register_bus | ( | const char * | bus_path, |
uint32_t | bus_clock | ||
[in] | bus_path | Path to the bus device file. |
[in] | bus_clock | Bus clock in Hz. |
0 | Bus registered successfully. |
<0 | Could not register the bus. The return value is a negative errno code. |
