RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
arm
raspberrypi
include
bsp
i2c.h
1
9
10
* Copyright (c) 2014-2015 Andre Marques <andre.lousa.marques at gmail.com>
11
12
* The license and distribution terms for this file may be
13
* found in the file LICENSE in this distribution or at
14
* http://www.rtems.org/license/LICENSE.
15
16
17
#ifndef LIBBSP_ARM_RASPBERRYPI_I2C_H
18
#define LIBBSP_ARM_RASPBERRYPI_I2C_H
19
20
dev/i2c/i2c.h
21
22
#ifdef __cplusplus
23
extern
"C"
24
#endif
/* __cplusplus */
25
37
#define BSC_CORE_CLK_HZ 150000000
38
44
#define DEFAULT_BUS_CLOCK 100000
45
57
extern
void
rpi_i2c_init
void
58
70
extern
int
rpi_i2c_register_bus
71
const
char
*bus_path,
72
uint32_t bus_clock
73
74
82
static
inline
int
rpi_setup_i2c_bus(
void
83
84
rpi_i2c_init
85
86
return
"/dev/i2c"
DEFAULT_BUS_CLOCK
87
88
91
#ifdef __cplusplus
92
93
#endif
/* __cplusplus */
94
95
#endif
/* LIBBSP_ARM_RASPBERRYPI_I2C_H */
int rpi_i2c_register_bus(const char *bus_path, uint32_t bus_clock)
Registers the Raspberry Pi BSC I2C bus with the Linux I2C User-Space API.
Definition:
i2c.c:364
rpi_i2c_init
void rpi_i2c_init(void)
Setups the Raspberry Pi GPIO header to activate the BSC I2C bus.
Definition:
i2c.c:416
i2c.h
Inter-Integrated Circuit (I2C) Driver API.
DEFAULT_BUS_CLOCK
Default bus clock.
Definition:
i2c.h:44
