    RTEMS
    5.1
API of the Watchdog driver for the lpc176x bsp in RTEMS. More...
#include <bsp/watchdog-defs.h>Go to the source code of this file.
| bool | lpc176x_been_reset_by_watchdog (void) |
| Checks if the watchdog was executed by software or not. Set when the watchdog timer times out, cleared by software.  More... | |
| void | lpc176x_watchdog_reset (void) |
| Resets the watchdog timer.  | |
| rtems_status_code | lpc176x_watchdog_config (lpc176x_microseconds tcount) |
| Configures the watchdog's timer.  More... | |
| rtems_status_code | lpc176x_watchdog_config_with_interrupt (lpc176x_wd_isr_funct interrupt, lpc176x_microseconds tcount) |
| Configures the timer watchdog using interrupt.  More... | |
  inline |
| rtems_status_code lpc176x_watchdog_config | ( | lpc176x_microseconds | tcount | ) |
| tcount | Timer's out value. |
| rtems_status_code lpc176x_watchdog_config_with_interrupt | ( | lpc176x_wd_isr_funct | interrupt, |
| lpc176x_microseconds | tcount | ||
| interrupt | Interrupt to register. |
 1.8.15
