22 #ifndef LIBBSP_ARM_LPC176X_WATCHDOG_DEFS_H    23 #define LIBBSP_ARM_LPC176X_WATCHDOG_DEFS_H    25 #include <rtems/score/cpu.h>    36 #define LPC176X_WDMOD_BASE 0x40000000U    37 #define LPC176X_WDFEED_CON 0XAAU    38 #define LPC176X_WDFEED_CFG 0X55U    39 #define LPC176X_WD_PRESCALER_DIVISOR 4000000U    40 #define LPC176X_WWDT_MOD_WDEN BSP_BIT32( 0 )    41 #define LPC176X_WWDT_MOD_WDRESET BSP_BIT32( 1 )    42 #define LPC176X_WWDT_MOD_WDTOF BSP_BIT32( 2 )    43 #define LPC176X_WWDT_MOD_WDINT BSP_BIT32( 3 )    44 #define LPC176X_WWDT_CLKSEL_WDSEL_IRC 0x0U    45 #define LPC176X_WWDT_CLKSEL_WDSEL_PCLK 0x1U    46 #define LPC176X_WWDT_CLKSEL_WDSEL_RTC 0x2U    47 #define LPC176X_WD_INTERRUPT_VECTOR_NUMBER 0U    48 #define LPC176X_WDMOD ( *(volatile uint32_t *) ( LPC176X_WDMOD_BASE + 0x00U ) )    49 #define LPC176X_WDTC ( *(volatile uint32_t *) ( LPC176X_WDMOD_BASE + 0x04U ) )    50 #define LPC176X_WDFEED ( *(volatile uint32_t *) ( LPC176X_WDMOD_BASE + \    52 #define LPC176X_WDTV ( *(volatile uint32_t *) ( LPC176X_WDMOD_BASE + 0x0CU ) )    53 #define LPC176X_WDCLKSEL ( *(volatile uint32_t *) ( LPC176X_WDMOD_BASE + \
Definitions types used by some devices in common.
void(* rtems_interrupt_handler)(void *)
Interrupt handler routine type.
Definition: irq-extension.h:79
rtems_interrupt_handler lpc176x_wd_isr_funct
A function that attends an interruption for a watchdog.
Definition: watchdog-defs.h:59
