RTEMS  5.1
io.h File Reference
Input/output module methods definitions. More...
#include <assert.h>
#include <bsp/io-defs.h>
void lpc176x_pin_select (uint32_t pin, lpc176x_pin_function function)
 Sets pin to the selected function. More...
void lpc176x_pin_set_mode (const uint32_t pin, const lpc176x_pin_mode mode)
 Sets pin to the selected mode. More...
rtems_status_code lpc176x_module_enable (lpc176x_module module, lpc176x_module_clock clock)
 Enables the module power and clock. More...
rtems_status_code lpc176x_module_disable (lpc176x_module module)
 Checks if the current module is turned off and disables a module. More...
bool lpc176x_module_is_enabled (lpc176x_module module)
 Checks if the current module is enabled or not. More...
◆ lpc176x_module_disable()
rtems_status_code lpc176x_module_disable ( lpc176x_module  module)
inline
Parameters
moduleRepresents the module to be disabled.
Returns
RTEMS_SUCCESFULL if the module was disabled succesfully.
◆ lpc176x_module_enable()
rtems_status_code lpc176x_module_enable ( lpc176x_module  module,
inline
Parameters
moduleRepresents the module to be enabled.
clockRepresents the clock to set for this module.
Returns
RTEMS_SUCCESFULL if the module was enabled succesfully.
◆ lpc176x_module_is_enabled()
bool lpc176x_module_is_enabled ( lpc176x_module  module)
Parameters
moduleRepresents the module to be checked.
Returns
TRUE if the module is enabled. FALSE otherwise.
◆ lpc176x_pin_select()
void lpc176x_pin_select ( uint32_t  pin,
inline
Parameters
pinThe pin to set.
functionDefines the function to set.
◆ lpc176x_pin_set_mode()
void lpc176x_pin_set_mode ( const uint32_t  pin,
Parameters
pinThe pin to set.
modeDefines the mode to set.
