35 #ifndef LIBCPU_VECTORS_H    36 #define LIBCPU_VECTORS_H    39 #include <rtems/score/cpuimpl.h>    54 #define ASM_RESET_VECTOR                     0x01    55 #define ASM_MACH_VECTOR                      0x02    56 #define ASM_PROT_VECTOR                      0x03    57 #define ASM_ISI_VECTOR                       0x04    58 #define ASM_EXT_VECTOR                       0x05    59 #define ASM_ALIGN_VECTOR                     0x06    60 #define ASM_PROG_VECTOR                      0x07    61 #define ASM_FLOAT_VECTOR                     0x08    62 #define ASM_DEC_VECTOR                       0x09    63 #define ASM_SYS_VECTOR                       0x0C    64 #define ASM_TRACE_VECTOR                     0x0D    66 #define ASM_PPC405_APU_UNAVAIL_VECTOR        ASM_60X_VEC_ASSIST_VECTOR    68 #define ASM_8XX_FLOATASSIST_VECTOR           0x0E    69 #define ASM_8XX_SOFTEMUL_VECTOR              0x10    70 #define ASM_8XX_ITLBMISS_VECTOR              0x11    71 #define ASM_8XX_DTLBMISS_VECTOR              0x12    72 #define ASM_8XX_ITLBERROR_VECTOR             0x13    73 #define ASM_8XX_DTLBERROR_VECTOR             0x14    74 #define ASM_8XX_DBREAK_VECTOR                0x1C    75 #define ASM_8XX_IBREAK_VECTOR                0x1D    76 #define ASM_8XX_PERIFBREAK_VECTOR            0x1E    77 #define ASM_8XX_DEVPORT_VECTOR               0x1F    79 #define ASM_5XX_FLOATASSIST_VECTOR           0x0E    80 #define ASM_5XX_SOFTEMUL_VECTOR              0x10    81 #define ASM_5XX_IPROT_VECTOR                 0x13    82 #define ASM_5XX_DPROT_VECTOR                 0x14    83 #define ASM_5XX_DBREAK_VECTOR                0x1C    84 #define ASM_5XX_IBREAK_VECTOR                0x1D    85 #define ASM_5XX_MEBREAK_VECTOR               0x1E    86 #define ASM_5XX_NMEBREAK_VECTOR              0x1F    88 #define ASM_60X_VEC_VECTOR                   0x0A    89 #define ASM_60X_PERFMON_VECTOR               0x0F    90 #define ASM_60X_IMISS_VECTOR                 0x10    91 #define ASM_60X_DLMISS_VECTOR                0x11    92 #define ASM_60X_DSMISS_VECTOR                0x12    93 #define ASM_60X_ADDR_VECTOR                  0x13    94 #define ASM_60X_SYSMGMT_VECTOR               0x14    95 #define ASM_60X_VEC_ASSIST_VECTOR            0x16    96 #define ASM_60X_ITM_VECTOR                   0x17    99 #define ASM_BOOKE_CRIT_VECTOR                0x01   105 #define ASM_BOOKE_DEC_VECTOR                 0x10   106 #define ASM_BOOKE_ITLBMISS_VECTOR            0x11   107 #define ASM_BOOKE_DTLBMISS_VECTOR            0x12   108 #define ASM_BOOKE_FIT_VECTOR                 0x13   109 #define ASM_BOOKE_WDOG_VECTOR                0x14   110 #define ASM_BOOKE_APU_VECTOR                 0x18   111 #define ASM_BOOKE_DEBUG_VECTOR               ASM_TRACE_VECTOR   114 #define ASM_E500_SPE_UNAVAILABLE_VECTOR      ASM_60X_VEC_VECTOR   115 #define ASM_E500_EMB_FP_DATA_VECTOR          0x19   116 #define ASM_E500_EMB_FP_ROUND_VECTOR         0x1A   117 #define ASM_E500_PERFMON_VECTOR              ASM_60X_PERFMON_VECTOR   120 #define ASM_E300_CRIT_VECTOR                 0x0A   121 #define ASM_E300_PERFMON_VECTOR              ASM_60X_PERFMON_VECTOR   122 #define ASM_E300_IMISS_VECTOR                ASM_60X_IMISS_VECTOR     123 #define ASM_E300_DLMISS_VECTOR               ASM_60X_DLMISS_VECTOR    124 #define ASM_E300_DSMISS_VECTOR               ASM_60X_DSMISS_VECTOR    125 #define ASM_E300_ADDR_VECTOR                 ASM_60X_ADDR_VECTOR   126 #define ASM_E300_SYSMGMT_VECTOR              ASM_60X_SYSMGMT_VECTOR   132 #define LAST_VALID_EXC                       0x1F   138 #define ASM_60X_VEC_VECTOR_OFFSET            0xf20   140 #define ASM_PPC405_FIT_VECTOR_OFFSET         0x1010   141 #define ASM_PPC405_WDOG_VECTOR_OFFSET        0x1020   142 #define ASM_PPC405_TRACE_VECTOR_OFFSET       0x2000   159 #define LINK_REGISTER_CALLEE_UPDATE_ROOM 4   161 #define EXC_GENERIC_SIZE (PPC_EXC_FRAME_SIZE + PPC_STACK_RED_ZONE_SIZE)   163 #define PPC_EXC_INTERRUPT_FRAME_SIZE CPU_INTERRUPT_FRAME_SIZE   165 #if defined(__ALTIVEC__) && !defined(PPC_MULTILIB_ALTIVEC)   166 #define EXC_VEC_OFFSET EXC_GENERIC_SIZE   167 #ifndef PPC_CACHE_ALIGNMENT   168 #error "Missing include file!"   174 #define EXC_VEC_SIZE   (16*20 + 2*PPC_CACHE_ALIGNMENT)   176 #define EXC_VEC_SIZE   (0)   184 #define EXCEPTION_FRAME_END (EXC_GENERIC_SIZE + EXC_VEC_SIZE)   230   PPC_EXC_CLASSIC_ASYNC = PPC_EXC_CLASSIC | PPC_EXC_ASYNC,
   231   PPC_EXC_405_CRITICAL = 4,
   232   PPC_EXC_405_CRITICAL_ASYNC = PPC_EXC_405_CRITICAL | PPC_EXC_ASYNC,
   233   PPC_EXC_BOOKE_CRITICAL = 6,
   234   PPC_EXC_BOOKE_CRITICAL_ASYNC = PPC_EXC_BOOKE_CRITICAL | PPC_EXC_ASYNC,
   235   PPC_EXC_E500_MACHCHK  = 8,
   236   PPC_EXC_E500_MACHCHK_ASYNC = PPC_EXC_E500_MACHCHK | PPC_EXC_ASYNC,
   247   return (
unsigned) category <= (unsigned) PPC_EXC_NAKED;
   300   size_t *prologue_size
   303 static inline void ppc_exc_initialize_interrupt_stack(uintptr_t stack_begin)
   305   uintptr_t stack_size = rtems_configuration_get_interrupt_stack_size();
   306   uintptr_t stack_end = stack_begin + stack_size;
   307   uintptr_t stack_pointer = stack_end - PPC_MINIMUM_STACK_FRAME_SIZE;
   310   stack_pointer &= ~((uintptr_t) CPU_STACK_ALIGNMENT - 1);
   313   *(uint32_t *) stack_pointer = 0;
   326   uintptr_t interrupt_stack_begin,
   343 static inline void ppc_exc_initialize(
void)
   368 #ifndef PPC_EXC_CONFIG_BOOKE_ONLY   399 #ifndef PPC_EXC_CONFIG_USE_FIXED_HANDLER void bsp_interrupt_dispatch(void)
Interrupt dispatch.
Definition: irq.c:83
int ppc_exc_handler_default(BSP_Exception_frame *f, unsigned int vector)
Default high-level exception handler.
Definition: ppc_exc_hdl.c:45
char _ISR_Stack_area_begin[]
The interrupt stack area begin.
ppc_exc_category ppc_exc_category_for_vector(const ppc_exc_categories *categories, unsigned vector)
Returns the category for the vector vector using the category set categories.
Definition: ppc_exc_categories.c:318
#define PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val)
Sets the Special Purpose Register with number spr to the value in val.
Definition: powerpc-utility.h:576
exception_handler_t globalExceptHdl
Global exception handler.
Definition: ppc_exc_hdl.c:52
uint8_t ppc_exc_categories[LAST_VALID_EXC+1]
Categorie set type.
Definition: vectors.h:243
void * ppc_exc_vector_address(unsigned vector, void *vector_base)
Returns the entry address of the vector.
Definition: ppc_exc_address.c:60
General purpose assembler macros, linker command file support and some inline functions for direct re...
rtems_status_code
Classic API Status.
Definition: status.h:43
void(* exception_handler_t)(BSP_Exception_frame *)
Global exception handler type.
Definition: vectors.h:209
uint32_t ppc_exc_msr_bits
Bits for MSR update.
Definition: ppc_exc_hdl.c:41
rtems_status_code ppc_exc_set_handler(unsigned vector, ppc_exc_handler_t hdl)
Set high-level exception handler.
Definition: ppc_exc_hdl.c:73
const ppc_exc_categories * ppc_exc_categories_for_cpu(ppc_cpu_id_t cpu)
Returns the category set for a CPU of type cpu, or NULL if there is no category set available for thi...
Definition: ppc_exc_categories.c:252
void ppc_exc_initialize_with_vector_base(uintptr_t interrupt_stack_begin, void *vector_base)
Initializes the exception handling.
Definition: ppc_exc_initialize.c:83
void C_exception_handler(BSP_Exception_frame *excPtr)
Default global exception handler.
Definition: ppc_exc_global_handler.c:22
uint32_t(* ppc_exc_get_DAR)(void)
Function for DAR access.
Definition: ppc_exc_print.c:60
ppc_exc_category
Exception categories.
Definition: vectors.h:226
ppc_exc_handler_t ppc_exc_handler_table[LAST_VALID_EXC+1]
High-level exception handler table.
Definition: ppc_exc_hdl.c:55
int(* ppc_exc_handler_t)(BSP_Exception_frame *f, unsigned vector)
High-level exception handler type.
Definition: vectors.h:359
ppc_exc_handler_t ppc_exc_get_handler(unsigned vector)
Returns the currently active high-level exception handler.
Definition: ppc_exc_hdl.c:61
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
int ppc_exc_alignment_handler(BSP_Exception_frame *frame, unsigned excNum)
Standard aligment handler.
Definition: ppc_exc_alignment.c:18
uint32_t ppc_exc_cache_wb_check
Cache write back check flag.
Definition: ppc_exc_initialize.c:30
rtems_status_code ppc_exc_make_prologue(unsigned vector, void *vector_base, ppc_exc_category category, uint32_t *prologue, size_t *prologue_size)
Makes a minimal prologue for the vector vector with the category category.
Definition: ppc_exc_prologue.c:104
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
