    RTEMS
    5.1
TMS570 interrupt support functions definitions. More...
#include <bsp.h>#include <bsp/irq-generic.h>#include <bsp/tms570-vim.h>#include <bsp/irq.h>#include <rtems/score/armv4.h>Functions | |
| void | tms570_irq_set_priority (rtems_vector_number vector, unsigned priority) |
| Set priority of the interrupt vector.  More... | |
| unsigned | tms570_irq_get_priority (rtems_vector_number vector) |
| Gets priority of the interrupt vector.  More... | |
| void | bsp_interrupt_dispatch (void) |
| Interrupt dispatch.  More... | |
| void | bsp_interrupt_vector_enable (rtems_vector_number vector) |
| enables interrupt vector in the HW  More... | |
| void | bsp_interrupt_vector_disable (rtems_vector_number vector) |
| disables interrupt vector in the HW  More... | |
| rtems_status_code | bsp_interrupt_facility_initialize (void) |
| Init function of interrupt module.  More... | |
| unsigned int | priorityTable [BSP_INTERRUPT_VECTOR_MAX+1] |
| void bsp_interrupt_dispatch | ( | void | ) |
Interrupt dispatch.
Called by OS to determine which interrupt occured. Function passes control to interrupt handler.
| unsigned tms570_irq_get_priority | ( | rtems_vector_number | vector | ) |
This function is here because of compability. It returns priority of the isr vector last set by tms570_irq_set_priority function.
| [in] | vector | vector of isr |
| 0 | vector is invalid. |
| priority | priority of the interrupt |
| void tms570_irq_set_priority | ( | rtems_vector_number | vector, |
| unsigned | priority | ||
This function is here because of compability. It should set priority of the interrupt vector.
| [in] | priority | new priority assigned to the vector |
 1.8.15
