782                                                 uint32_t * speed_in_hz);
   805                                                 uint32_t speed_in_hz);
   810 #define alt_i2c_cfg_to_speed(i2c_dev, speed_in_hz, cfg) alt_i2c_master_config_speed_get((i2c_dev), (cfg), (speed_in_hz))   815 #define alt_i2c_speed_to_cfg(i2c_dev, speed_in_hz, cfg) alt_i2c_master_config_speed_set((i2c_dev), (cfg), (speed_in_hz))   890                                           uint16_t *hold_time);
   910                                           const uint16_t hold_time);
  1072                                        const uint8_t data);
  1227                                         const bool issue_restart,
  1228                                         const bool issue_stop);
  1294                                        const bool issue_restart,
  1295                                        const bool issue_stop);
  1345                                    const bool issue_restart,
  1346                                    const bool issue_stop);
  1398                                     const uint8_t value,
  1399                                     const bool issue_restart,
  1400                                     const bool issue_stop);
  1484                                             const bool issue_restart,
  1485                                             const bool issue_stop);
  1747 #define ALT_I2C_RX_FIFO_NUM_ENTRIES     64  1796                                           uint32_t *num_entries);
  1815                                               uint8_t *threshold);
  1834                                               const uint8_t threshold);
  1856 #define ALT_I2C_TX_FIFO_NUM_ENTRIES     64  1905                                           uint32_t *num_entries);
  1924                                               uint8_t *threshold);
  1943                                               const uint8_t threshold);
 Definition: alt_i2c.h:137
Definition: alt_i2c.h:227
ALT_STATUS_CODE alt_i2c_sda_hold_time_get(ALT_I2C_DEV_t *i2c_dev, uint16_t *hold_time)
Definition: alt_i2c.c:626
Definition: alt_i2c.h:186
Definition: alt_i2c.h:106
ALT_STATUS_CODE alt_i2c_slave_bulk_transmit(ALT_I2C_DEV_t *i2c_dev, const void *data, const size_t size)
Definition: alt_i2c.c:859
ALT_STATUS_CODE alt_i2c_master_config_speed_get(ALT_I2C_DEV_t *i2c_dev, const ALT_I2C_MASTER_CONFIG_t *cfg, uint32_t *speed_in_hz)
Definition: alt_i2c.c:480
bool nack_enable
Definition: alt_i2c.h:588
ALT_I2C_TRANSFER_TYPE_e
Definition: alt_i2c.h:101
ALT_STATUS_CODE alt_i2c_general_call_ack_is_enabled(ALT_I2C_DEV_t *i2c_dev)
Definition: alt_i2c.c:1566
ALT_STATUS_CODE alt_i2c_master_transmit(ALT_I2C_DEV_t *i2c_dev, const void *data, const size_t size, const bool issue_restart, const bool issue_stop)
Definition: alt_i2c.c:1048
ALT_STATUS_CODE alt_i2c_sda_hold_time_set(ALT_I2C_DEV_t *i2c_dev, const uint16_t hold_time)
Definition: alt_i2c.c:643
ALT_STATUS_CODE alt_i2c_rx_dma_threshold_set(ALT_I2C_DEV_t *i2c_dev, uint8_t threshold)
Definition: alt_i2c.c:1968
ALT_STATUS_CODE alt_i2c_rx_fifo_is_empty(ALT_I2C_DEV_t *i2c_dev)
Definition: alt_i2c.c:1738
Definition: alt_i2c.h:236
Definition: alt_i2c.h:382
I2C slave device control.
Definition: i2c.h:292
Definition: alt_i2c.h:423
Definition: alt_i2c.h:107
ALT_I2C_ADDR_MODE_t addr_mode
Definition: alt_i2c.h:529
Definition: alt_i2c.h:284
Definition: 8xx_immap.h:216
Definition: alt_i2c.h:105
enum ALT_I2C_MODE_e ALT_I2C_MODE_t
ALT_STATUS_CODE alt_i2c_slave_config_get(ALT_I2C_DEV_t *i2c_dev, ALT_I2C_SLAVE_CONFIG_t *cfg)
Definition: alt_i2c.c:545
ALT_STATUS_CODE alt_i2c_issue_write(ALT_I2C_DEV_t *i2c_dev, const uint8_t value, const bool issue_restart, const bool issue_stop)
Definition: alt_i2c.c:1382
ALT_STATUS_CODE alt_i2c_int_status_get(ALT_I2C_DEV_t *i2c_dev, uint32_t *status)
Definition: alt_i2c.c:1590
uint32_t last_target
Definition: alt_i2c.h:127
ALT_I2C_MODE_e
Definition: alt_i2c.h:149
ALT_STATUS_CODE alt_i2c_tx_fifo_threshold_set(ALT_I2C_DEV_t *i2c_dev, const uint8_t threshold)
Definition: alt_i2c.c:1920
bool restart_enable
Definition: alt_i2c.h:533
ALT_STATUS_CODE alt_i2c_int_enable(ALT_I2C_DEV_t *i2c_dev, const uint32_t mask)
Definition: alt_i2c.c:1703
enum ALT_I2C_TRANSFER_TYPE_e ALT_I2C_TRANSFER_TYPE_t
ALT_STATUS_CODE alt_i2c_int_clear(ALT_I2C_DEV_t *i2c_dev, const uint32_t mask)
Definition: alt_i2c.c:1624
Definition: alt_i2c.h:416
uint16_t ss_scl_hcnt
Definition: alt_i2c.h:551
Definition: alt_i2c.h:355
Definition: alt_i2c.h:309
Definition: alt_i2c.h:487
enum ALT_I2C_SPEED_e ALT_I2C_SPEED_t
Definition: alt_i2c.h:581
Definition: alt_i2c.h:136
ALT_STATUS_CODE alt_i2c_tx_dma_threshold_get(ALT_I2C_DEV_t *i2c_dev, uint8_t *threshold)
Definition: alt_i2c.c:1985
ALT_STATUS_CODE alt_i2c_slave_receive(ALT_I2C_DEV_t *i2c_dev, uint8_t *data)
Definition: alt_i2c.c:825
Definition: alt_i2c.h:172
Definition: alt_i2c.h:433
ALT_STATUS_CODE alt_i2c_int_disable(ALT_I2C_DEV_t *i2c_dev, const uint32_t mask)
Definition: alt_i2c.c:1687
ALT_I2C_CTLR_e
Definition: alt_i2c.h:134
ALT_STATUS_CODE alt_i2c_disable(ALT_I2C_DEV_t *i2c_dev)
Definition: alt_i2c.c:317
Definition: alt_i2c.h:104
Definition: alt_i2c.h:321
Definition: alt_i2c.h:139
ALT_STATUS_CODE alt_i2c_master_receive(ALT_I2C_DEV_t *i2c_dev, void *data, const size_t size, const bool issue_restart, const bool issue_stop)
Definition: alt_i2c.c:1226
ALT_STATUS_CODE alt_i2c_slave_transmit(ALT_I2C_DEV_t *i2c_dev, const uint8_t data)
Definition: alt_i2c.c:848
Definition: alt_i2c.h:138
uint32_t alt_freq_t
Definition: alt_clock_manager.h:66
ALT_STATUS_CODE alt_i2c_tx_fifo_level_get(ALT_I2C_DEV_t *i2c_dev, uint32_t *num_entries)
Definition: alt_i2c.c:1888
ALT_STATUS_CODE alt_i2c_op_mode_get(ALT_I2C_DEV_t *i2c_dev, ALT_I2C_MODE_t *mode)
Definition: alt_i2c.c:681
ALT_STATUS_CODE alt_i2c_read(ALT_I2C_DEV_t *i2c_dev, uint8_t *val)
Definition: alt_i2c.c:783
ALT_STATUS_CODE alt_i2c_rx_fifo_is_full(ALT_I2C_DEV_t *i2c_dev)
Definition: alt_i2c.c:1758
ALT_I2C_ADDR_MODE_e
Definition: alt_i2c.h:184
ALT_STATUS_CODE alt_i2c_master_target_set(ALT_I2C_DEV_t *i2c_dev, uint32_t target_addr)
Definition: alt_i2c.c:899
ALT_STATUS_CODE alt_i2c_master_config_speed_set(ALT_I2C_DEV_t *i2c_dev, ALT_I2C_MASTER_CONFIG_t *cfg, uint32_t speed_in_hz)
Definition: alt_i2c.c:504
Definition: alt_i2c.h:400
ALT_STATUS_CODE alt_i2c_issue_read(ALT_I2C_DEV_t *i2c_dev, const bool issue_restart, const bool issue_stop)
Definition: alt_i2c.c:1419
Definition: alt_i2c.h:205
Definition: alt_i2c.h:250
ALT_STATUS_CODE alt_i2c_master_config_get(ALT_I2C_DEV_t *i2c_dev, ALT_I2C_MASTER_CONFIG_t *cfg)
Definition: alt_i2c.c:379
Definition: alt_i2c.h:123
alt_freq_t clock_freq
Definition: alt_i2c.h:126
ALT_STATUS_CODE alt_i2c_op_mode_set(ALT_I2C_DEV_t *i2c_dev, const ALT_I2C_MODE_t mode)
Definition: alt_i2c.c:708
ALT_STATUS_CODE alt_i2c_master_target_get(ALT_I2C_DEV_t *i2c_dev, uint32_t *target_addr)
Definition: alt_i2c.c:887
ALT_STATUS_CODE alt_i2c_init(const ALT_I2C_CTLR_t i2c, ALT_I2C_DEV_t *i2c_dev)
Definition: alt_i2c.c:176
ALT_STATUS_CODE alt_i2c_tx_fifo_is_empty(ALT_I2C_DEV_t *i2c_dev)
Definition: alt_i2c.c:1848
ALT_STATUS_CODE alt_i2c_tx_dma_threshold_set(ALT_I2C_DEV_t *i2c_dev, uint8_t threshold)
Definition: alt_i2c.c:1996
ALT_STATUS_CODE alt_i2c_master_general_call(ALT_I2C_DEV_t *i2c_dev, const void *data, const size_t size, const bool issue_restart, const bool issue_stop)
Definition: alt_i2c.c:1456
uint16_t ss_scl_lcnt
Definition: alt_i2c.h:555
ALT_STATUS_CODE alt_i2c_general_call_ack_disable(ALT_I2C_DEV_t *i2c_dev)
Definition: alt_i2c.c:1490
ALT_STATUS_CODE alt_i2c_is_busy(ALT_I2C_DEV_t *i2c_dev)
Definition: alt_i2c.c:763
Definition: alt_i2c.h:453
struct ALT_I2C_SLAVE_CONFIG_s ALT_I2C_SLAVE_CONFIG_t
ALT_STATUS_CODE alt_i2c_rx_fifo_level_get(ALT_I2C_DEV_t *i2c_dev, uint32_t *num_entries)
Definition: alt_i2c.c:1778
Definition: alt_i2c.h:152
Definition: alt_i2c.h:392
enum ALT_I2C_TX_ABORT_CAUSE_e ALT_I2C_TX_ABORT_CAUSE_t
Definition: alt_i2c.h:292
ALT_STATUS_CODE alt_i2c_rx_dma_threshold_get(ALT_I2C_DEV_t *i2c_dev, uint8_t *threshold)
Definition: alt_i2c.c:1957
Definition: alt_i2c.h:579
ALT_STATUS_CODE alt_i2c_tx_fifo_is_full(ALT_I2C_DEV_t *i2c_dev)
Definition: alt_i2c.c:1868
Definition: alt_i2c.h:264
Definition: alt_i2c.h:151
ALT_STATUS_CODE alt_i2c_uninit(ALT_I2C_DEV_t *i2c_dev)
Definition: alt_i2c.c:271
Definition: alt_i2c.h:468
ALT_STATUS_CODE alt_i2c_write(ALT_I2C_DEV_t *i2c_dev, const uint8_t val)
Definition: alt_i2c.c:803
ALT_STATUS_CODE alt_i2c_slave_config_set(ALT_I2C_DEV_t *i2c_dev, const ALT_I2C_SLAVE_CONFIG_t *cfg)
Definition: alt_i2c.c:567
enum ALT_I2C_STATUS_e ALT_I2C_STATUS_t
Definition: alt_i2c.h:409
enum ALT_I2C_ADDR_MODE_e ALT_I2C_ADDR_MODE_t
ALT_STATUS_CODE alt_i2c_master_config_set(ALT_I2C_DEV_t *i2c_dev, const ALT_I2C_MASTER_CONFIG_t *cfg)
Definition: alt_i2c.c:407
Definition: alt_i2c.h:503
ALT_STATUS_CODE alt_i2c_rx_fifo_threshold_set(ALT_I2C_DEV_t *i2c_dev, const uint8_t threshold)
Definition: alt_i2c.c:1810
Definition: alt_i2c.h:170
void * location
Definition: alt_i2c.h:125
Definition: alt_i2c.h:330
int32_t ALT_STATUS_CODE
Definition: hwlib.h:60
uint8_t fs_spklen
Definition: alt_i2c.h:567
Definition: alt_i2c.h:315
Definition: alt_i2c.h:353
ALT_I2C_SPEED_t speed_mode
Definition: alt_i2c.h:548
Definition: alt_i2c.h:527
Definition: alt_i2c.h:216
uint32_t addr
Definition: alt_i2c.h:584
Definition: alt_i2c.h:364
ALT_I2C_SPEED_e
Definition: alt_i2c.h:168
ALT_STATUS_CODE alt_i2c_tx_fifo_threshold_get(ALT_I2C_DEV_t *i2c_dev, uint8_t *threshold)
Definition: alt_i2c.c:1904
Definition: alt_i2c.h:197
unsigned size
Definition: tte.h:74
ALT_STATUS_CODE alt_i2c_is_enabled(ALT_I2C_DEV_t *i2c_dev)
Definition: alt_i2c.c:366
ALT_STATUS_CODE alt_i2c_general_call_ack_enable(ALT_I2C_DEV_t *i2c_dev)
Definition: alt_i2c.c:1528
ALT_STATUS_CODE alt_i2c_int_raw_status_get(ALT_I2C_DEV_t *i2c_dev, uint32_t *status)
Definition: alt_i2c.c:1607
Definition: alt_i2c.h:478
ALT_STATUS_CODE alt_i2c_reset(ALT_I2C_DEV_t *i2c_dev)
Definition: alt_i2c.c:213
Definition: alt_i2c.h:461
Definition: alt_i2c.h:103
ALT_STATUS_CODE alt_i2c_rx_fifo_threshold_get(ALT_I2C_DEV_t *i2c_dev, uint8_t *threshold)
Definition: alt_i2c.c:1794
uint16_t fs_scl_hcnt
Definition: alt_i2c.h:559
Definition: alt_i2c.h:373
struct ALT_I2C_MASTER_CONFIG_s ALT_I2C_MASTER_CONFIG_t
enum ALT_I2C_CTLR_e ALT_I2C_CTLR_t
ALT_I2C_STATUS_e
Definition: alt_i2c.h:195
ALT_STATUS_CODE alt_i2c_tx_abort_cause_get(ALT_I2C_DEV_t *i2c_dev, ALT_I2C_TX_ABORT_CAUSE_t *cause)
Definition: alt_i2c.c:1720
Definition: alt_i2c.h:188
uint16_t fs_scl_lcnt
Definition: alt_i2c.h:563
ALT_STATUS_CODE alt_i2c_enable(ALT_I2C_DEV_t *i2c_dev)
Definition: alt_i2c.c:298
