| ALT_STATUS_CODE  | alt_clk_lock_status_clear (ALT_CLK_PLL_LOCK_STATUS_t lock_stat_mask) |
| uint32_t  | alt_clk_lock_status_get (void) |
| ALT_STATUS_CODE  | alt_clk_pll_is_locked (ALT_CLK_t pll) |
| ALT_STATUS_CODE  | alt_clk_safe_mode_clear (void) |
| bool  | alt_clk_is_in_safe_mode (ALT_CLK_SAFE_DOMAIN_t clk_domain) |
| ALT_STATUS_CODE  | alt_clk_pll_bypass_disable (ALT_CLK_t pll) |
| ALT_STATUS_CODE  | alt_clk_pll_bypass_enable (ALT_CLK_t pll, bool use_input_mux) |
| ALT_STATUS_CODE  | alt_clk_pll_is_bypassed (ALT_CLK_t pll) |
| ALT_STATUS_CODE  | alt_clk_clock_disable (ALT_CLK_t clk) |
| ALT_STATUS_CODE  | alt_clk_clock_enable (ALT_CLK_t clk) |
| ALT_STATUS_CODE  | alt_clk_is_enabled (ALT_CLK_t clk) |
| ALT_CLK_t  | alt_clk_source_get (ALT_CLK_t clk) |
| ALT_STATUS_CODE  | alt_clk_source_set (ALT_CLK_t clk, ALT_CLK_t ref_clk) |
| ALT_STATUS_CODE  | alt_clk_ext_clk_freq_set (ALT_CLK_t clk, alt_freq_t freq) |
| alt_freq_t  | alt_clk_ext_clk_freq_get (ALT_CLK_t clk) |
| ALT_STATUS_CODE  | alt_clk_pll_cfg_get (ALT_CLK_t pll, ALT_CLK_PLL_CFG_t *pll_cfg) |
| ALT_STATUS_CODE  | alt_clk_pll_cfg_set (ALT_CLK_t pll, const ALT_CLK_PLL_CFG_t *pll_cfg) |
| ALT_STATUS_CODE  | alt_clk_pll_vco_cfg_get (ALT_CLK_t pll, uint32_t *mult, uint32_t *div) |
| ALT_STATUS_CODE  | alt_clk_pll_vco_cfg_set (ALT_CLK_t pll, uint32_t mult, uint32_t div) |
| ALT_STATUS_CODE  | alt_clk_pll_vco_freq_get (ALT_CLK_t pll, alt_freq_t *freq) |
| uint32_t  | alt_clk_pll_guard_band_get (ALT_CLK_t pll) |
| ALT_STATUS_CODE  | alt_clk_pll_guard_band_set (ALT_CLK_t pll, uint32_t guard_band) |
| ALT_STATUS_CODE  | alt_clk_divider_get (ALT_CLK_t clk, uint32_t *div) |
| ALT_STATUS_CODE  | alt_clk_divider_set (ALT_CLK_t clk, uint32_t div) |
| ALT_STATUS_CODE  | alt_clk_freq_get (ALT_CLK_t clk, alt_freq_t *freq) |
| ALT_STATUS_CODE  | alt_clk_irq_disable (ALT_CLK_PLL_LOCK_STATUS_t lock_stat_mask) |
| ALT_STATUS_CODE  | alt_clk_irq_enable (ALT_CLK_PLL_LOCK_STATUS_t lock_stat_mask) |
| ALT_STATUS_CODE  | alt_clk_group_cfg_raw_get (ALT_CLK_GRP_t clk_group, ALT_CLK_GROUP_RAW_CFG_t *clk_group_raw_cfg) |
| ALT_STATUS_CODE  | alt_clk_group_cfg_raw_set (const ALT_CLK_GROUP_RAW_CFG_t *clk_group_raw_cfg) |
ALT_STATUS_CODE  | alt_clk_clkmgr_init (void) |
Contains definitions for the Altera Hardware Libraries Clock Manager Application Programming Interface
