#define  | UINT12_MAX   (4096) |
#define  | ALT_ORIGINAL_GUARDBAND_VAL   20 |
#define  | ALT_GUARDBAND_LIMIT   20 |
#define  | ALT_CLK_PLL_MULT_MAX   4095 |
#define  | ALT_CLK_PLL_DIV_MAX   63 |
#define  | ALT_CLK_PLL_CNTR_MAX   511 |
#define  | ALT_CLK_PLL_RST_BIT_C0   0x00000001 |
#define  | ALT_CLK_PLL_RST_BIT_C1   0x00000002 |
#define  | ALT_CLK_PLL_RST_BIT_C2   0x00000004 |
#define  | ALT_CLK_PLL_RST_BIT_C3   0x00000008 |
#define  | ALT_CLK_PLL_RST_BIT_C4   0x00000010 |
#define  | ALT_CLK_PLL_RST_BIT_C5   0x00000020 |
| #define  | ALT_CLK_MGR_PLL_LOCK_BITS |
#define  | ALT_CLKMGR_ALTERA_OFST   0xe0 |
#define  | ALT_CLKMGR_ALTERA_MPUCLK_OFST   0x0 |
#define  | ALT_CLKMGR_ALTERA_MAINCLK_OFST   0x4 |
#define  | ALT_CLKMGR_ALTERA_DBGATCLK_OFST   0x8 |
#define  | ALT_CLKMGR_ALTERA_ADDR   ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_ALTERA_OFST)) |
#define  | ALT_CLKMGR_ALTERA_MPUCLK_ADDR   ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ALTERA_ADDR) + ALT_CLKMGR_ALTERA_MPUCLK_OFST)) |
#define  | ALT_CLKMGR_ALTERA_MAINCLK_ADDR   ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ALTERA_ADDR) + ALT_CLKMGR_ALTERA_MAINCLK_OFST)) |
#define  | ALT_CLKMGR_ALTERA_DBGATCLK_ADDR   ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ALTERA_ADDR) + ALT_CLKMGR_ALTERA_DBGATCLK_OFST)) |
#define  | ALT_CLKMGR_ALTERA_MPUCLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0) |
#define  | ALT_CLKMGR_ALTERA_MAINCLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0) |
#define  | ALT_CLKMGR_ALTERA_DBGATCLK_CNT_GET(value)   (((value) & 0x000001ff) >> 0) |
#define  | ALT_SW_MANAGED_CLK_WAIT_CTRDIV   30      /* 30 or more MPU clock cycles */ |
#define  | ALT_SW_MANAGED_CLK_WAIT_HWCTRDIV   40 |
#define  | ALT_SW_MANAGED_CLK_WAIT_BYPASS   30 |
#define  | ALT_SW_MANAGED_CLK_WAIT_SAFEREQ   30 |
#define  | ALT_SW_MANAGED_CLK_WAIT_SAFEEXIT   30 |
#define  | ALT_SW_MANAGED_CLK_WAIT_NANDCLK   8       /* 8 or more MPU clock cycles */ |
#define  | ALT_BYPASS_TIMEOUT_CNT   50 |
#define  | ALT_TIMEOUT_PHASE_SYNC   300 |
| #define  | alt_within_delta(ref,  neu,  prcnt) |
#define  | ALT_PREVENT_GLITCH_BYP   true |
#define  | ALT_PREVENT_GLITCH_EXSAFE   true |
#define  | ALT_PREVENT_GLITCH_CNTRRST   true |
#define  | ALT_PREVENT_GLITCH_CHGC1   true |
#define  | ALT_CLK_PLL_VCO_CHG_METHOD_TEST_MODE   false |
#define  | ALT_CLK_WITHIN_FREQ_LIMITS_TEST_MODE   false |
ALT_STATUS_CODE  | alt_clk_plls_settle_wait (void) |
| ALT_STATUS_CODE  | alt_clk_lock_status_clear (ALT_CLK_PLL_LOCK_STATUS_t lock_stat_mask) |
| uint32_t  | alt_clk_lock_status_get (void) |
| ALT_STATUS_CODE  | alt_clk_pll_is_locked (ALT_CLK_t pll) |
| ALT_STATUS_CODE  | alt_clk_safe_mode_clear (void) |
| bool  | alt_clk_is_in_safe_mode (ALT_CLK_SAFE_DOMAIN_t clk_domain) |
| ALT_STATUS_CODE  | alt_clk_pll_bypass_disable (ALT_CLK_t pll) |
| ALT_STATUS_CODE  | alt_clk_pll_bypass_enable (ALT_CLK_t pll, bool use_input_mux) |
| ALT_STATUS_CODE  | alt_clk_pll_is_bypassed (ALT_CLK_t pll) |
ALT_CLK_t  | alt_clk_pll_source_get (ALT_CLK_t pll) |
| ALT_STATUS_CODE  | alt_clk_clock_disable (ALT_CLK_t clk) |
| ALT_STATUS_CODE  | alt_clk_clock_enable (ALT_CLK_t clk) |
| ALT_STATUS_CODE  | alt_clk_is_enabled (ALT_CLK_t clk) |
| ALT_CLK_t  | alt_clk_source_get (ALT_CLK_t clk) |
| ALT_STATUS_CODE  | alt_clk_source_set (ALT_CLK_t clk, ALT_CLK_t ref_clk) |
| ALT_STATUS_CODE  | alt_clk_ext_clk_freq_set (ALT_CLK_t clk, alt_freq_t freq) |
| alt_freq_t  | alt_clk_ext_clk_freq_get (ALT_CLK_t clk) |
| ALT_STATUS_CODE  | alt_clk_pll_cfg_get (ALT_CLK_t pll, ALT_CLK_PLL_CFG_t *pll_cfg) |
| ALT_STATUS_CODE  | alt_clk_pll_cfg_set (ALT_CLK_t pll, const ALT_CLK_PLL_CFG_t *pll_cfg) |
| ALT_STATUS_CODE  | alt_clk_pll_vco_cfg_get (ALT_CLK_t pll, uint32_t *mult, uint32_t *div) |
| ALT_STATUS_CODE  | alt_clk_pll_vco_cfg_set (ALT_CLK_t pll, uint32_t mult, uint32_t div) |
| ALT_STATUS_CODE  | alt_clk_pll_vco_freq_get (ALT_CLK_t pll, alt_freq_t *freq) |
| uint32_t  | alt_clk_pll_guard_band_get (ALT_CLK_t pll) |
| ALT_STATUS_CODE  | alt_clk_pll_guard_band_set (ALT_CLK_t pll, uint32_t guard_band) |
| ALT_STATUS_CODE  | alt_clk_divider_get (ALT_CLK_t clk, uint32_t *div) |
| ALT_STATUS_CODE  | alt_clk_divider_set (ALT_CLK_t clk, uint32_t div) |
| ALT_STATUS_CODE  | alt_clk_freq_get (ALT_CLK_t clk, alt_freq_t *freq) |
| ALT_STATUS_CODE  | alt_clk_irq_disable (ALT_CLK_PLL_LOCK_STATUS_t lock_stat_mask) |
| ALT_STATUS_CODE  | alt_clk_irq_enable (ALT_CLK_PLL_LOCK_STATUS_t lock_stat_mask) |
| ALT_STATUS_CODE  | alt_clk_group_cfg_raw_get (ALT_CLK_GRP_t clk_group, ALT_CLK_GROUP_RAW_CFG_t *clk_group_raw_cfg) |
| ALT_STATUS_CODE  | alt_clk_group_cfg_raw_set (const ALT_CLK_GROUP_RAW_CFG_t *clk_group_raw_cfg) |
ALT_STATUS_CODE  | alt_clk_id_to_string (ALT_CLK_t clk_id, char *output, size_t size) |
ALT_STATUS_CODE  | alt_clk_pll_cntr_maxfreq_recalc (ALT_CLK_t clk, ALT_PLL_CNTR_FREQMAX_t *maxfreq) |
ALT_STATUS_CODE  | alt_clk_clkmgr_init (void) |
