    RTEMS
    5.1
Modules | |
| SoCAL Memory Bit Set/Clr/XOR/Replace Utilities | |
| SoCAL Memory Read/Write Utilities | |
| #define | ALT_CAST(type, ptr) ((type) (ptr)) |
This file contains utility and support functions for the Altera SoCAL.
| #define ALT_CAST | ( | type, | |
| ptr | |||
| ) | ((type) (ptr)) |
Cast the pointer to specified pointer type.
Note: This macro expands to ptr value only for assembler language targets.
| type | The pointer type to cast to |
| ptr | The pointer to apply the type cast to |
 1.8.15
