    RTEMS
    5.1
Go to the documentation of this file.   38 #ifndef __ALT_MPUSCU_H__    39 #define __ALT_MPUSCU_H__    57 #define ALT_HPS_ADDR 0x00    63 #define GLOBALTMR_BASE                      (ALT_MPUSCU_OFST + GLOBALTMR_MODULE_BASE_OFFSET)    64 #define CPU_WDTGPT_TMR_BASE                 (ALT_MPUSCU_OFST + WDOG_TIMER_MODULE_BASE_OFFSET)    65 #define CPU_PRIVATE_TMR_BASE                (ALT_MPUSCU_OFST + CPU_PRIV_TIMER_MODULE_BASE_OFFSET)    66 #define CPU_INT_CTRL_BASE                   (ALT_MPUSCU_OFST + INT_CONTROLLER_MODULE_BASE_OFFSET)    67 #define CPU_INT_DIST_BASE                   (ALT_MPUSCU_OFST + INT_DISTRIBUTOR_MODULE_BASE_OFFSET)    72 #define GLOBALTMR_MODULE_BASE_OFFSET        0x00000200    73 #define GLOBALTMR_CNTR_LO_REG_OFFSET        0x00000000    74 #define GLOBALTMR_CNTR_HI_REG_OFFSET        0x00000004    75 #define GLOBALTMR_CTRL_REG_OFFSET           0x00000008    76 #define GLOBALTMR_INT_STAT_REG_OFFSET       0x0000000C    77 #define GLOBALTMR_COMP_LO_REG_OFFSET        0x00000010    78 #define GLOBALTMR_COMP_HI_REG_OFFSET        0x00000014    79 #define GLOBALTMR_AUTOINC_REG_OFFSET        0x00000018    82 #define GLOBALTMR_ENABLE_BIT                0x00000001    83 #define GLOBALTMR_COMP_ENABLE_BIT           0x00000002    84 #define GLOBALTMR_INT_ENABLE_BIT            0x00000004    85 #define GLOBALTMR_AUTOINC_ENABLE_BIT        0x00000008    86 #define GLOBALTMR_PS_MASK                   0x0000FF00    87 #define GLOBALTMR_PS_SHIFT                  8    88 #define GLOBALTMR_INT_STATUS_BIT            0x00000001    91 #define GLOBALTMR_MAX                       0xFFFFFFFF    92 #define GLOBALTMR_PS_MAX                    0x000000FF    96 #define CPU_PRIV_TIMER_MODULE_BASE_OFFSET   0x00000600    97 #define CPU_PRIV_TMR_LOAD_REG_OFFSET        0x00000000    98 #define CPU_PRIV_TMR_CNTR_REG_OFFSET        0x00000004    99 #define CPU_PRIV_TMR_CTRL_REG_OFFSET        0x00000008   100 #define CPU_PRIV_TMR_INT_STATUS_REG_OFFSET  0x0000000C   103 #define CPU_PRIV_TMR_ENABLE                 0x00000001   104 #define CPU_PRIV_TMR_AUTO_RELOAD            0x00000002   105 #define CPU_PRIV_TMR_INT_EN                 0x00000004   106 #define CPU_PRIV_TMR_PS_MASK                0x0000FF00   107 #define CPU_PRIV_TMR_PS_SHIFT               8   108 #define CPU_PRIV_TMR_INT_STATUS             0x00000001   111 #define CPU_PRIV_TMR_MAX                    0xFFFFFFFF   112 #define CPU_PRIV_TMR_PS_MAX                 0x000000FF   117 #define WDOG_TIMER_MODULE_BASE_OFFSET       0x00000620   118 #define WDOG_LOAD_REG_OFFSET                0x00000000   119 #define WDOG_CNTR_REG_OFFSET                0x00000004   120 #define WDOG_CTRL_REG_OFFSET                0x00000008   121 #define WDOG_INTSTAT_REG_OFFSET             0x0000000C   122 #define WDOG_RSTSTAT_REG_OFFSET             0x00000010   123 #define WDOG_DISABLE_REG_OFFSET             0x00000014   127 #define WDOG_TMR_ENABLE                     0x00000001   128 #define WDOG_AUTO_RELOAD                    0x00000002   129 #define WDOG_INT_EN                         0x00000004   130 #define WDOG_WDT_MODE                       0x00000008   131 #define WDOG_PS_MASK                        0x0000FF00   132 #define WDOG_PS_SHIFT                       8   134 #define WDOG_INT_STAT_BIT                   0x00000001   136 #define WDOG_RST_STAT_BIT                   0x00000001   139 #define WDOG_TMR_MAX                        UINT32_MAX   140 #define WDOG_PS_MAX                         UINT8_MAX   141 #define WDOG_DISABLE_VAL0                   0x12345678   142 #define WDOG_DISABLE_VAL1                   0x87654321   148 #define INT_CONTROLLER_MODULE_BASE_OFFSET   0x00000100   149 #define INT_DISTRIBUTOR_MODULE_BASE_OFFSET  0x00001000   150 #define INT_DIST_TYPE_REG                   0x00000004   154 #define MPUSCU_MAX                          0x00001FFF
