| RTEMS_STATIC_ASSERT (offsetof(Per_CPU_Control, cpu_per_cpu.isr_dispatch_disable)==SPARC_PER_CPU_ISR_DISPATCH_DISABLE, SPARC_PER_CPU_ISR_DISPATCH_DISABLE) |
| SPARC_ASSERT_OFFSET (g5, G5) |
| SPARC_ASSERT_OFFSET (g7, G7) |
| RTEMS_STATIC_ASSERT (offsetof(Context_Control, l0_and_l1)==L0_OFFSET, Context_Control_offset_L0) |
| RTEMS_STATIC_ASSERT (offsetof(Context_Control, l0_and_l1)+4==L1_OFFSET, Context_Control_offset_L1) |
| SPARC_ASSERT_OFFSET (l2, L2) |
| SPARC_ASSERT_OFFSET (l3, L3) |
| SPARC_ASSERT_OFFSET (l4, L4) |
| SPARC_ASSERT_OFFSET (l5, L5) |
| SPARC_ASSERT_OFFSET (l6, L6) |
| SPARC_ASSERT_OFFSET (l7, L7) |
| SPARC_ASSERT_OFFSET (i0, I0) |
| SPARC_ASSERT_OFFSET (i1, I1) |
| SPARC_ASSERT_OFFSET (i2, I2) |
| SPARC_ASSERT_OFFSET (i3, I3) |
| SPARC_ASSERT_OFFSET (i4, I4) |
| SPARC_ASSERT_OFFSET (i5, I5) |
| SPARC_ASSERT_OFFSET (i6_fp, I6_FP) |
| SPARC_ASSERT_OFFSET (i7, I7) |
| SPARC_ASSERT_OFFSET (o6_sp, O6_SP) |
| SPARC_ASSERT_OFFSET (o7, O7) |
| SPARC_ASSERT_OFFSET (psr, PSR) |
| SPARC_ASSERT_OFFSET (isr_dispatch_disable, ISR_DISPATCH_DISABLE_STACK) |
| SPARC_ASSERT_ISF_OFFSET (psr, PSR) |
| SPARC_ASSERT_ISF_OFFSET (pc, PC) |
| SPARC_ASSERT_ISF_OFFSET (npc, NPC) |
| SPARC_ASSERT_ISF_OFFSET (g1, G1) |
| SPARC_ASSERT_ISF_OFFSET (g2, G2) |
| SPARC_ASSERT_ISF_OFFSET (g3, G3) |
| SPARC_ASSERT_ISF_OFFSET (g4, G4) |
| SPARC_ASSERT_ISF_OFFSET (g5, G5) |
| SPARC_ASSERT_ISF_OFFSET (g7, G7) |
| SPARC_ASSERT_ISF_OFFSET (i0, I0) |
| SPARC_ASSERT_ISF_OFFSET (i1, I1) |
| SPARC_ASSERT_ISF_OFFSET (i2, I2) |
| SPARC_ASSERT_ISF_OFFSET (i3, I3) |
| SPARC_ASSERT_ISF_OFFSET (i4, I4) |
| SPARC_ASSERT_ISF_OFFSET (i5, I5) |
| SPARC_ASSERT_ISF_OFFSET (i6_fp, I6_FP) |
| SPARC_ASSERT_ISF_OFFSET (i7, I7) |
| SPARC_ASSERT_ISF_OFFSET (y, Y) |
| SPARC_ASSERT_ISF_OFFSET (tpc, TPC) |
| RTEMS_STATIC_ASSERT (sizeof(CPU_Interrupt_frame)==CONTEXT_CONTROL_INTERRUPT_FRAME_SIZE, CPU_Interrupt_frame_size) |
| RTEMS_STATIC_ASSERT (sizeof(CPU_Interrupt_frame) % CPU_ALIGNMENT==0, CPU_Interrupt_frame_alignment) |
| void | _CPU_Initialize (void) |
| | CPU initialization. More...
| uint32_t | _CPU_ISR_Get_level (void) |
| | Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode. More...
| void | _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
| | This routine installs a "raw" interrupt handler directly into the processor's vector table. More...
| void | _CPU_ISR_install_vector (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
| | This routine installs an interrupt vector. More...
| void | _CPU_Context_Initialize (Context_Control *the_context, uint32_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area) |
| | Initialize the context to a state suitable for starting a task after a context restore operation. More...
SPARC CPU Dependent Source.
