RTEMS Run-Time Linker Object File Unresolved Relocations Table. More...
#include <errno.h>#include <inttypes.h>#include <stdlib.h>#include <stdio.h>#include <rtems/rtl/rtl.h>#include "rtl-error.h"#include "rtl-unresolved.h"#include "rtl-trace.h"
| struct | rtems_rtl_unresolved_reloc_data_s |
| Struct to pass relocation data in the interator. More... | |
Typedefs | |
| typedef struct rtems_rtl_unresolved_reloc_data_s | rtems_rtl_unresolved_reloc_data_t |
| Struct to pass relocation data in the interator. | |
| bool | rtems_rtl_unresolved_table_open (rtems_rtl_unresolved_t *unresolved, size_t block_recs) |
| Open an unresolved relocation table. More... | |
| void | rtems_rtl_unresolved_table_close (rtems_rtl_unresolved_t *unresolved) |
| Close the table and erase the blocks. More... | |
| bool | rtems_rtl_unresolved_interate (rtems_rtl_unresolved_iterator_t iterator, void *data) |
| Iterate over the table of unresolved entries. | |
| bool | rtems_rtl_unresolved_add (rtems_rtl_obj_t *obj, const uint16_t flags, const char *name, const uint16_t sect, const rtems_rtl_word_t *rel) |
| Add a relocation to the list of unresolved relocations. More... | |
| void | rtems_rtl_unresolved_resolve (void) |
| Resolve the unresolved symbols. | |
| bool | rtems_rtl_unresolved_remove (rtems_rtl_obj_t *obj, const char *name, const uint16_t sect, const rtems_rtl_word_t *rel) |
| Remove a relocation from the list of unresolved relocations. More... | |
| bool rtems_rtl_unresolved_add | ( | rtems_rtl_obj_t * | obj, |
| const uint16_t | flags, | ||
| const char * | name, | ||
| const uint16_t | sect, | ||
| const rtems_rtl_word_t * | rel | ||
| unresolved | The unresolved symbol table. |
| obj | The object table the symbols are for. |
| flags | Format specific flags. |
| name | The symbol name the relocation references. |
| sect | The target section number the relocation references. |
| rel | The format specific relocation data. |
| true | The relocation has been added. |
| false | The relocation could not be added. |
| bool rtems_rtl_unresolved_remove | ( | rtems_rtl_obj_t * | obj, |
| esyms | The exported symbol table. |
| size | The size of the table in bytes. |
References rtems_rtl_unresolved().
| void rtems_rtl_unresolved_table_close | ( | rtems_rtl_unresolved_t * | unresolved | ) |
| unreolved | Close the unresolved table. |
References rtems_rtl_unresolved_s::blocks, rtems_chain_first(), and rtems_chain_is_tail().
| bool rtems_rtl_unresolved_table_open | ( | rtems_rtl_unresolved_t * | unresolved, |
| size_t | block_records | ||
| unresolv | The unresolved table to open. |
| block_records | The number of records per block allocated. |
| true | The table is open. |
| false | The unresolved relocation table could not created. The RTL error has the error. |
References rtems_rtl_unresolved_s::block_recs, rtems_rtl_unresolved_s::blocks, and rtems_chain_initialize_empty().
