Macros | Typedefs | Functions
rtl-trace.h File Reference
RTEMS Run-Time Linker ELF Trace Support. More...
#include <stdbool.h>
#include <stdint.h>
Include dependency graph for rtl-trace.h:
#define RTEMS_RTL_TRACE   1
 Set to 1 to build trace support in to the RTL code.
#define RTEMS_RTL_TRACE_DETAIL   (1UL << 0)
 List of tracing bits for the various parts of the link editor.
#define RTEMS_RTL_TRACE_WARNING   (1UL << 1)
#define RTEMS_RTL_TRACE_LOAD   (1UL << 2)
#define RTEMS_RTL_TRACE_UNLOAD   (1UL << 3)
#define RTEMS_RTL_TRACE_SECTION   (1UL << 4)
#define RTEMS_RTL_TRACE_SYMBOL   (1UL << 5)
#define RTEMS_RTL_TRACE_RELOC   (1UL << 6)
#define RTEMS_RTL_TRACE_GLOBAL_SYM   (1UL << 7)
#define RTEMS_RTL_TRACE_LOAD_SECT   (1UL << 8)
#define RTEMS_RTL_TRACE_ALLOCATOR   (1UL << 9)
#define RTEMS_RTL_TRACE_UNRESOLVED   (1UL << 10)
#define RTEMS_RTL_TRACE_CACHE   (1UL << 11)
#define RTEMS_RTL_TRACE_ALL   (0xffffffffUL & ~(RTEMS_RTL_TRACE_CACHE))
typedef uint32_t rtems_rtl_trace_mask
 The type of the mask.
bool rtems_rtl_trace (rtems_rtl_trace_mask mask)
 Call to check if this part is bring traced. More...
rtems_rtl_trace_mask rtems_rtl_trace_set_mask (rtems_rtl_trace_mask mask)
 Set the mask. More...
rtems_rtl_trace_mask rtems_rtl_trace_clear_mask (rtems_rtl_trace_mask mask)
 Clear the mask. More...
int rtems_rtl_trace_shell_command (int argc, char *argv[])
 Add shell trace shell command.
◆ rtems_rtl_trace()
bool rtems_rtl_trace ( rtems_rtl_trace_mask  mask)
If RTEMS_RTL_TRACE is defined to 0 the code is dead code elminiated when built with -Os, -O2, or higher.
Parameters
maskThe part of the API to trace.
Return values
trueTracing is active for the mask.
falseDo not trace.
Referenced by rtems_rtl_elf_relocate_rela(), rtems_rtl_load_object(), rtems_rtl_obj_cache_close(), rtems_rtl_obj_cache_flush(), rtems_rtl_obj_load_sections(), rtems_rtl_unload_object(), and rtems_rtl_unresolved_resolve().
◆ rtems_rtl_trace_clear_mask()
rtems_rtl_trace_mask rtems_rtl_trace_clear_mask ( rtems_rtl_trace_mask  mask)
Clear the mask.
Parameters
maskThe mask bits to clear.
Returns
The previous mask.
◆ rtems_rtl_trace_set_mask()
rtems_rtl_trace_mask rtems_rtl_trace_set_mask ( rtems_rtl_trace_mask  mask)
Set the mask.
Parameters
maskThe mask bits to set.
Returns
The previous mask.
