19 #ifndef _RTEMS_SCORE_INTERR_H 20 #define _RTEMS_SCORE_INTERR_H 139 INTERNAL_ERROR_NO_CONFIGURATION_TABLE,
140 INTERNAL_ERROR_NO_CPU_TABLE,
141 INTERNAL_ERROR_TOO_LITTLE_WORKSPACE,
142 INTERNAL_ERROR_WORKSPACE_ALLOCATION,
143 INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL,
144 INTERNAL_ERROR_THREAD_EXITTED,
145 INTERNAL_ERROR_INCONSISTENT_MP_INFORMATION,
146 INTERNAL_ERROR_INVALID_NODE,
147 INTERNAL_ERROR_NO_MPCI,
148 INTERNAL_ERROR_BAD_PACKET,
149 INTERNAL_ERROR_OUT_OF_PACKETS,
150 INTERNAL_ERROR_OUT_OF_GLOBAL_OBJECTS,
151 INTERNAL_ERROR_OUT_OF_PROXIES,
152 INTERNAL_ERROR_INVALID_GLOBAL_ID,
153 INTERNAL_ERROR_BAD_STACK_HOOK,
154 INTERNAL_ERROR_BAD_ATTRIBUTES,
155 INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY,
156 OBSOLETE_INTERNAL_ERROR_IMPLEMENTATION_BLOCKING_OPERATION_CANCEL,
157 INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE,
158 INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0,
159 OBSOLETE_INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP,
160 INTERNAL_ERROR_GXX_KEY_ADD_FAILED,
161 INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED,
162 INTERNAL_ERROR_NO_MEMORY_FOR_HEAP,
163 INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR,
164 INTERNAL_ERROR_RESOURCE_IN_USE
230 Internal_errors_t the_error
uintptr_t CPU_Uint32ptr
Type that can store a 32-bit integer or a pointer.
Definition: score/cpu/arm/rtems/score/types.h:41
Fatal source of SMP domain.
Definition: interr.h:124
Fatal source for the block device cache.
Definition: interr.h:68
Fatal source for application specific errors.
Definition: interr.h:75
Fatal source for BSP errors.
Definition: interr.h:92
Fatal source of assert().
Definition: interr.h:101
Errors of the core system.
Definition: interr.h:51
Fatal source of the exceptions.
Definition: interr.h:117
void _Terminate(Internal_errors_Source the_source, bool is_internal, Internal_errors_t the_error)
Initiates system termination.
Definition: interr.c:31
The last available fatal source.
Definition: interr.h:132
Errors of the POSIX API.
Definition: interr.h:61
Internal_errors_Core_list
A list of errors which are generated internally by the executive core.
Definition: interr.h:138
Fatal source of exit().
Definition: interr.h:82
Fatal source of the stack checker.
Definition: interr.h:108
Internal_errors_Information _Internal_errors_What_happened
When a fatal error occurs, the error information is stored here.
Definition: interr.c:29
#define RTEMS_COMPILER_NO_RETURN_ATTRIBUTE
The following macro is a compiler specific way to indicate that the method will NOT return to the cal...
Definition: basedefs.h:162
Information Included in Every Function in the Executive.
This type lists the possible sources from which an error can be reported.
Definition: interr.h:45
Errors of the RTEMS API.
Definition: interr.h:56
