This handler encapsulates functionality which provides the foundation Semaphore services used in all of the APIs supported by RTEMS. More...
Files | |
file | interr.c |
Initiates system termination. | |
struct | Internal_errors_Information |
This type holds the fatal error information. More... | |
Typedefs | |
typedef CPU_Uint32ptr | Internal_errors_t |
Enumerations | |
enum | Internal_errors_Source { INTERNAL_ERROR_CORE, INTERNAL_ERROR_RTEMS_API, INTERNAL_ERROR_POSIX_API, RTEMS_FATAL_SOURCE_BDBUF, RTEMS_FATAL_SOURCE_APPLICATION, RTEMS_FATAL_SOURCE_EXIT, RTEMS_FATAL_SOURCE_BSP, RTEMS_FATAL_SOURCE_ASSERT, RTEMS_FATAL_SOURCE_STACK_CHECKER, RTEMS_FATAL_SOURCE_EXCEPTION, RTEMS_FATAL_SOURCE_SMP, RTEMS_FATAL_SOURCE_LAST = 0xffffffff } |
This type lists the possible sources from which an error can be reported. More... | |
enum | Internal_errors_Core_list { INTERNAL_ERROR_NO_CONFIGURATION_TABLE, INTERNAL_ERROR_NO_CPU_TABLE, INTERNAL_ERROR_TOO_LITTLE_WORKSPACE, INTERNAL_ERROR_WORKSPACE_ALLOCATION, INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL, INTERNAL_ERROR_THREAD_EXITTED, INTERNAL_ERROR_INCONSISTENT_MP_INFORMATION, INTERNAL_ERROR_INVALID_NODE, INTERNAL_ERROR_NO_MPCI, INTERNAL_ERROR_BAD_PACKET, INTERNAL_ERROR_OUT_OF_PACKETS, INTERNAL_ERROR_OUT_OF_GLOBAL_OBJECTS, INTERNAL_ERROR_OUT_OF_PROXIES, INTERNAL_ERROR_INVALID_GLOBAL_ID, INTERNAL_ERROR_BAD_STACK_HOOK, INTERNAL_ERROR_BAD_ATTRIBUTES, INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY, OBSOLETE_INTERNAL_ERROR_IMPLEMENTATION_BLOCKING_OPERATION_CANCEL, INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE, INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0, OBSOLETE_INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP, INTERNAL_ERROR_GXX_KEY_ADD_FAILED, INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED, INTERNAL_ERROR_NO_MEMORY_FOR_HEAP, INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR, INTERNAL_ERROR_RESOURCE_IN_USE } |
A list of errors which are generated internally by the executive core. | |
void | _Terminate (Internal_errors_Source the_source, bool is_internal, Internal_errors_t the_error) |
Initiates system termination. More... | |
Internal_errors_Information | _Internal_errors_What_happened |
When a fatal error occurs, the error information is stored here. | |
Enumerator | |
INTERNAL_ERROR_CORE | Errors of the core system.
INTERNAL_ERROR_RTEMS_API | Errors of the RTEMS API. |
INTERNAL_ERROR_POSIX_API | Errors of the POSIX API. |
RTEMS_FATAL_SOURCE_BDBUF | Fatal source for the block device cache.
RTEMS_FATAL_SOURCE_APPLICATION | Fatal source for application specific errors. The fatal code is application specific. |
RTEMS_FATAL_SOURCE_EXIT | Fatal source of exit(). The fatal code is the exit() status code. |
RTEMS_FATAL_SOURCE_BSP | Fatal source for BSP errors. The fatal codes are defined in <bsp/fatal.h>. Examples are interrupt and exception initialization.
RTEMS_FATAL_SOURCE_ASSERT | Fatal source of assert(). The fatal code is the pointer value of the assert context.
RTEMS_FATAL_SOURCE_STACK_CHECKER | Fatal source of the stack checker. The fatal code is the object name of the executing task. |
RTEMS_FATAL_SOURCE_EXCEPTION | Fatal source of the exceptions. The fatal code is the pointer value of the exception frame pointer.
RTEMS_FATAL_SOURCE_SMP | Fatal source of SMP domain.
RTEMS_FATAL_SOURCE_LAST | The last available fatal source. This enum value ensures that the enum type needs at least 32-bits for architectures with short enums. |
void _Terminate | ( | Internal_errors_Source | the_source, |
bool | is_internal, | ||
Internal_errors_t | the_error | ||
This routine is invoked when the application or the executive itself determines that a fatal error has occurred or a final system state is reached (for example after exit()).
The first action is to disable interrupts.
The second action of this function is to call the fatal handler of the user extensions. For the initial extensions the following conditions are required
For the initial extensions the read-write data (including BSS segment) is not required on single processor configurations. On SMP configurations however the read-write data must be initialized since this function must determine the state of the other processors and request them to shut-down if necessary.
Non-initial extensions require in addition valid read-write data. The BSP may install an initial extension that performs a system reset. In this case the non-initial extensions will be not called.
Once all fatal handler executed the error information will be stored to _Internal_errors_What_happened and the system state is set to SYSTEM_STATE_TERMINATED.
The final step is to call the CPU specific _CPU_Fatal_halt().
[in] | the_source | The fatal source indicating the subsystem the fatal condition originated in. |
[in] | is_internal | Indicates if the fatal condition was generated internally to the executive. |
[in] | the_error | The fatal error code. This value must be interpreted with respect to the source. |
Referenced by _CPU_ISR_install_vector(), _MPCI_Get_packet(), _MPCI_Handler_initialization(), _MPCI_Receive_server(), _Objects_MP_Allocate_and_open(), _Objects_MP_Close(), _Objects_MP_Handler_early_initialization(), _POSIX_Fatal_error(), rtems_fatal_error_occurred(), and rtems_shutdown_executive().
