#include <sys/cdefs.h>
#define | YPERR_BADARGS 1 /* args to function are bad */ |
#define | YPERR_RPC 2 /* RPC failure */ |
#define | YPERR_DOMAIN 3 /* can't bind to a server for domain */ |
#define | YPERR_MAP 4 /* no such map in server's domain */ |
#define | YPERR_KEY 5 /* no such key in map */ |
#define | YPERR_YPERR 6 /* some internal YP server or client error */ |
#define | YPERR_RESRC 7 /* local resource allocation failure */ |
#define | YPERR_NOMORE 8 /* no more records in map database */ |
#define | YPERR_PMAP 9 /* can't communicate with portmapper */ |
#define | YPERR_YPBIND 10 /* can't communicate with ypbind */ |
#define | YPERR_YPSERV 11 /* can't communicate with ypserv */ |
#define | YPERR_NODOM 12 /* local domain name not set */ |
#define | YPERR_BADDB 13 /* YP data base is bad */ |
#define | YPERR_VERS 14 /* YP version mismatch */ |
#define | YPERR_ACCESS 15 /* access violation */ |
#define | YPERR_BUSY 16 /* database is busy */ |
#define | YPOP_CHANGE 1 /* change, do not add */ |
#define | YPOP_INSERT 2 /* add, do not change */ |
#define | YPOP_DELETE 3 /* delete this entry */ |
#define | YPOP_STORE 4 /* add, or change */ |
__BEGIN_DECLS int | yp_bind (char *dom) |
int | _yp_dobind (char *dom, struct dom_binding **ypdb) |
void | yp_unbind (char *dom) |
int | yp_get_default_domain (char **domp) |
int | yp_match (char *indomain, char *inmap, const char *inkey, int inkeylen, char **outval, int *outvallen) |
int | yp_first (char *indomain, char *inmap, char **outkey, int *outkeylen, char **outval, int *outvallen) |
int | yp_next (char *indomain, char *inmap, char *inkey, int inkeylen, char **outkey, int *outkeylen, char **outval, int *outvallen) |
int | yp_master (char *indomain, char *inmap, char **outname) |
int | yp_order (char *indomain, char *inmap, int *outorder) |
int | yp_all (char *indomain, char *inmap, struct ypall_callback *incallback) |
char * | yperr_string (int incode) |
char * | ypbinderr_string (int incode) |
int | ypprot_err (unsigned int incode) |
