rtems-4.11.3
libnetworking
vm
vm_kern.h
1
2
* Copyright (c) 1991, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
* This code is derived from software contributed to Berkeley by
6
* The Mach Operating System project at Carnegie-Mellon University.
7
8
9
* modification, are permitted provided that the following conditions
10
* are met:
11
* 1. Redistributions of source code must retain the above copyright
12
* notice, this list of conditions and the following disclaimer.
13
* 2. Redistributions in binary form must reproduce the above copyright
14
* notice, this list of conditions and the following disclaimer in the
15
* documentation and/or other materials provided with the distribution.
16
* 4. Neither the name of the University nor the names of its contributors
17
* may be used to endorse or promote products derived from this software
18
* without specific prior written permission.
19
20
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
21
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
24
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
25
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
26
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
27
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
28
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
29
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
30
* SUCH DAMAGE.
31
32
33
34
35
* Copyright (c) 1987, 1990 Carnegie-Mellon University.
36
* All rights reserved.
37
38
* Authors: Avadis Tevanian, Jr., Michael Wayne Young
39
40
* Permission to use, copy, modify and distribute this software and
41
* its documentation is hereby granted, provided that both the copyright
42
* notice and this permission notice appear in all copies of the
43
* software, derivative works or modified versions, and any portions
44
* thereof, and that both notices appear in supporting documentation.
45
46
* CARNEGIE MELLON ALLOWS FREE USE OF THIS SOFTWARE IN ITS "AS IS"
47
* CONDITION. CARNEGIE MELLON DISCLAIMS ANY LIABILITY OF ANY KIND
48
* FOR ANY DAMAGES WHATSOEVER RESULTING FROM THE USE OF THIS SOFTWARE.
49
50
* Carnegie Mellon requests users of this software to return to
51
52
* Software Distribution Coordinator or Software.Distribution@CS.CMU.EDU
53
* School of Computer Science
54
* Carnegie Mellon University
55
* Pittsburgh PA 15213-3890
56
57
* any improvements or extensions that they make and grant Carnegie the
58
* rights to redistribute these changes.
59
60
* $FreeBSD: src/sys/vm/vm_kern.h,v 1.28 2005/01/07 02:29:27 imp Exp $
61
62
63
64
#ifndef _VM_VM_KERN_H_
65
#define _VM_VM_KERN_H_ 1
66
67
#if !defined(__rtems__)
68
/* Kernel memory management definitions. */
69
extern
vm_map_t buffer_map;
70
extern
vm_map_t kernel_map;
71
extern
vm_map_t kmem_map;
72
extern
vm_map_t clean_map;
73
extern
vm_map_t exec_map;
74
extern
vm_map_t pipe_map;
75
extern
u_int vm_kmem_size;
76
#endif
77
78
#endif
/* _VM_VM_KERN_H_ */
