rtems-4.11.3
libmisc
untar
untar.h
1
9
10
* Written by: Jake Janovetz <janovetz@tempest.ece.uiuc.edu>
11
12
* The license and distribution terms for this file may be
13
* found in the file LICENSE in this distribution or at
14
* http://www.rtems.org/license/LICENSE.
15
16
17
#ifndef _RTEMS_UNTAR_H
18
#define _RTEMS_UNTAR_H
19
20
#include <stddef.h>
21
#include <tar.h>
22
29
#ifdef __cplusplus
30
extern
"C"
31
#endif
32
33
#define UNTAR_SUCCESSFUL 0
34
#define UNTAR_FAIL 1
35
#define UNTAR_INVALID_CHECKSUM 2
36
#define UNTAR_INVALID_HEADER 3
37
38
39
int
Untar_FromMemory(
void
*tar_buf,
size_t
size);
40
int
Untar_FromFile(
const
char
*tar_name);
41
42
43
* This converts octal ASCII number representations into an
44
* unsigned long. Only support 32-bit numbers for now.
45
46
extern
unsigned
long
47
_rtems_octal2ulong(
const
char
*octascii,
size_t
len);
48
49
50
* Compute the TAR checksum and check with the value in
51
* the archive. The checksum is computed over the entire
52
* header, but the checksum field is substituted with blanks.
53
54
extern
int
55
_rtems_tar_header_checksum(
const
char
*bufr);
56
57
#ifdef __cplusplus
58
59
#endif
60
61
#endif
/* _RTEMS_UNTAR_H */
