#define | TIOCMODG _IOR('t', 3, int) /* get modem control state */ |
#define | TIOCMODS _IOW('t', 4, int) /* set modem control state */ |
#define | TIOCM_LE 0001 /* line enable */ |
#define | TIOCM_DTR 0002 /* data terminal ready */ |
#define | TIOCM_RTS 0004 /* request to send */ |
#define | TIOCM_ST 0010 /* secondary transmit */ |
#define | TIOCM_SR 0020 /* secondary receive */ |
#define | TIOCM_CTS 0040 /* clear to send */ |
#define | TIOCM_CAR 0100 /* carrier detect */ |
#define | TIOCM_CD TIOCM_CAR |
#define | TIOCM_RNG 0200 /* ring */ |
#define | TIOCM_RI TIOCM_RNG |
#define | TIOCM_DSR 0400 /* data set ready */ |
#define | TIOCEXCL _IO('t', 13) /* set exclusive use of tty */ |
#define | TIOCNXCL _IO('t', 14) /* reset exclusive use of tty */ |
#define | TIOCFLUSH _IOW('t', 16, int) /* flush buffers */ |
#define | TIOCGETA _IOR('t', 19, struct termios) /* get termios struct */ |
#define | TIOCSETA _IOW('t', 20, struct termios) /* set termios struct */ |
#define | TIOCSETAW _IOW('t', 21, struct termios) /* drain output, set */ |
#define | TIOCSETAF _IOW('t', 22, struct termios) /* drn out, fls in, set */ |
#define | TIOCGETD _IOR('t', 26, int) /* get line discipline */ |
#define | TIOCSETD _IOW('t', 27, int) /* set line discipline */ |
#define | TIOCSBRK _IO('t', 123) /* set break bit */ |
#define | TIOCCBRK _IO('t', 122) /* clear break bit */ |
#define | TIOCSDTR _IO('t', 121) /* set data terminal ready */ |
#define | TIOCCDTR _IO('t', 120) /* clear data terminal ready */ |
#define | TIOCGPGRP _IOR('t', 119, int) /* get pgrp of tty */ |
#define | TIOCSPGRP _IOW('t', 118, int) /* set pgrp of tty */ |
#define | TIOCOUTQ _IOR('t', 115, int) /* output queue size */ |
#define | TIOCSTI _IOW('t', 114, char) /* simulate terminal input */ |
#define | TIOCNOTTY _IO('t', 113) /* void tty association */ |
#define | TIOCPKT _IOW('t', 112, int) /* pty: set/clear packet mode */ |
#define | TIOCPKT_DATA 0x00 /* data packet */ |
#define | TIOCPKT_FLUSHREAD 0x01 /* flush packet */ |
#define | TIOCPKT_FLUSHWRITE 0x02 /* flush packet */ |
#define | TIOCPKT_STOP 0x04 /* stop output */ |
#define | TIOCPKT_START 0x08 /* start output */ |
#define | TIOCPKT_NOSTOP 0x10 /* no more ^S, ^Q */ |
#define | TIOCPKT_DOSTOP 0x20 /* now do ^S ^Q */ |
#define | TIOCPKT_IOCTL 0x40 /* state change of pty driver */ |
#define | TIOCSTOP _IO('t', 111) /* stop output, like ^S */ |
#define | TIOCSTART _IO('t', 110) /* start output, like ^Q */ |
#define | TIOCMSET _IOW('t', 109, int) /* set all modem bits */ |
#define | TIOCMBIS _IOW('t', 108, int) /* bis modem bits */ |
#define | TIOCMBIC _IOW('t', 107, int) /* bic modem bits */ |
#define | TIOCMGET _IOR('t', 106, int) /* get all modem bits */ |
#define | TIOCREMOTE _IOW('t', 105, int) /* remote input editing */ |
#define | TIOCGWINSZ _IOR('t', 104, struct winsize) /* get window size */ |
#define | TIOCSWINSZ _IOW('t', 103, struct winsize) /* set window size */ |
#define | TIOCUCNTL _IOW('t', 102, int) /* pty: set/clr usr cntl mode */ |
#define | TIOCSTAT _IO('t', 101) /* simulate ^T status message */ |
#define | UIOCCMD(n) _IO('u', n) /* usr cntl op "n" */ |
#define | TIOCCONS _IOW('t', 98, int) /* become virtual console */ |
#define | TIOCSCTTY _IO('t', 97) /* become controlling tty */ |
#define | TIOCEXT _IOW('t', 96, int) /* pty: external processing */ |
#define | TIOCSIG _IO('t', 95) /* pty: generate signal */ |
#define | TIOCDRAIN _IO('t', 94) /* wait till output drained */ |
#define | TIOCMSDTRWAIT _IOW('t', 91, int) /* modem: set wait on close */ |
#define | TIOCMGDTRWAIT _IOR('t', 90, int) /* modem: get wait on close */ |
#define | TIOCTIMESTAMP |
#define | TIOCDCDTIMESTAMP |
#define | TIOCSDRAINWAIT _IOW('t', 87, int) /* set ttywait timeout */ |
#define | TIOCGDRAINWAIT _IOR('t', 86, int) /* get ttywait timeout */ |
#define | TIOCDSIMICROCODE |
#define | TTYDISC 0 /* termios tty line discipline */ |
#define | TABLDISC 3 /* tablet discipline */ |
#define | SLIPDISC 4 /* serial IP discipline */ |
#define | PPPDISC 5 /* PPP discipline */ |
