Time of Day Handler API. More...
#include <rtems/score/tod.h>#include <rtems/score/timestamp.h>#include <rtems/score/timecounterimpl.h>#include <sys/time.h>#include <time.h>
| struct | TOD_Control |
| TOD control. More... | |
| #define | TOD_SECONDS_PER_MINUTE (uint32_t)60 |
| This constant represents the number of seconds in a minute. | |
| #define | TOD_MINUTES_PER_HOUR (uint32_t)60 |
| This constant represents the number of minutes per hour. | |
| #define | TOD_MONTHS_PER_YEAR (uint32_t)12 |
| This constant represents the number of months in a year. | |
| #define | TOD_DAYS_PER_YEAR (uint32_t)365 |
| This constant represents the number of days in a non-leap year. | |
| #define | TOD_HOURS_PER_DAY (uint32_t)24 |
| This constant represents the number of hours per day. | |
| #define | TOD_SECONDS_PER_DAY |
| This constant represents the number of seconds in a day which does not include a leap second. More... | |
| #define | TOD_SECONDS_PER_NON_LEAP_YEAR (365 * TOD_SECONDS_PER_DAY) |
| This constant represents the number of seconds in a non-leap year. | |
| #define | TOD_MILLISECONDS_PER_SECOND (uint32_t)1000 |
| This constant represents the number of millisecond in a second. | |
| #define | TOD_MICROSECONDS_PER_SECOND (uint32_t)1000000 |
| This constant represents the number of microseconds in a second. | |
| #define | TOD_NANOSECONDS_PER_SECOND (uint32_t)1000000000 |
| This constant represents the number of nanoseconds in a second. | |
| #define | TOD_NANOSECONDS_PER_MICROSECOND (uint32_t)1000 |
| This constant represents the number of nanoseconds in a mircosecond. | |
| #define | TOD_SECONDS_1970_THROUGH_1988 |
| Seconds from January 1, 1970 to January 1, 1988. More... | |
| #define | TOD_BASE_YEAR 1988 |
| Earliest year to which an time of day can be initialized. More... | |
| #define | TOD_TICKS_PER_SECOND TOD_TICKS_PER_SECOND_method() |
| Gets number of ticks in a second. More... | |
| void | _TOD_Handler_initialization (void) |
| Initializes the time of day handler. More... | |
| void | _TOD_Set_with_timestamp (const Timestamp_Control *tod_as_timestamp) |
| Sets the time of day from timestamp. More... | |
| void | _TOD_Tickle_ticks (void) |
| Increments time of day at each clock tick. More... | |
| uint32_t | TOD_TICKS_PER_SECOND_method (void) |
| RTEMS_INLINE_ROUTINE void | _TOD_Get_timeval (struct timeval *time) |
| This routine returns a timeval based upon the internal timespec format TOD. | |
| void | _TOD_Adjust (const Timestamp_Control timestamp) |
| Adjust the Time of Time. More... | |
| RTEMS_INLINE_ROUTINE bool | _TOD_Is_set (void) |
| Check if the TOD is Set. More... | |
| SCORE_EXTERN TOD_Control | _TOD |
| #define TOD_BASE_YEAR 1988 |
The following constant define the earliest year to which an time of day can be initialized. This is considered the epoch.
| #define TOD_SECONDS_1970_THROUGH_1988 |
Used to account for differences between POSIX API and RTEMS core. The timespec format time is kept in POSIX compliant form.
