#include <rtems.h>#include <rtems/error.h>#include <rtems/pty.h>#include <rtems/shell.h>#include <rtems/telnetd.h>#include <rtems/bspIo.h>#include <sys/socket.h>#include <netinet/in.h>#include <arpa/inet.h>#include <unistd.h>#include <stdlib.h>#include <stdio.h>#include <string.h>#include <syslog.h>#include <rtems/userenv.h>#include <rtems/rtems_bsdnet.h>
| struct | shell_args |
| union | uni_sa |
| struct | wrap_delete_args |
Typedefs | |
| typedef union uni_sa | uni_sa |
| char * | telnet_get_pty (int socket) |
| int | telnet_pty_initialize (void) |
| rtems_id | telnetd_dflt_spawn (const char *name, unsigned priority, unsigned stackSize, void(*fn)(void *), void *fnarg) |
| rtems_status_code | rtems_telnetd_initialize (void) |
| Initializes the Telnet subsystem. More... | |
| rtems_id | telnetd_dflt_spawn (const char *name, unsigned int priority, unsigned int stackSize, void(*fn)(void *), void *fnarg) |
| rtems_id(* | telnetd_spawn_task )(const char *, unsigned, unsigned, void(*)(void *), void *) = telnetd_dflt_spawn |
| rtems_status_code rtems_telnetd_initialize | ( | void | ) |
Uses the application provided rtems_telnetd_config configuration table.
References rtems_telnetd_config_table::command, RTEMS_ID_NONE, RTEMS_IO_ERROR, RTEMS_RESOURCE_IN_USE, and rtems_telnetd_config.
