RTL Object. More...
#include <rtl-obj.h>
Data Fields | |
| rtems_chain_node | link |
| The node's link in the chain. More... | |
| uint32_t | flags |
| The status of the object file. More... | |
| uint32_t | users |
| References to the object file. More... | |
| int | format |
| The format of the object file. More... | |
| const char * | fname |
| The file name for the object. More... | |
| const char * | oname |
| The object file name. More... | |
| const char * | aname |
| The archive name containing the object. More... | |
| off_t | ooffset |
| The object offset in the archive. More... | |
| size_t | fsize |
| Size of the object file. More... | |
| rtems_chain_control | sections |
| The sections of interest in the object file. More... | |
| rtems_rtl_obj_sym_t * | local_table |
| Local symbol table. More... | |
| size_t | local_syms |
| Local symbol count. More... | |
| size_t | local_size |
| Local symbol memory usage. More... | |
| rtems_rtl_obj_sym_t * | global_table |
| Global symbol table. More... | |
| size_t | global_syms |
| Global symbol count. More... | |
| size_t | global_size |
| Global symbol memory usage. More... | |
| uint32_t | unresolved |
| The number of unresolved relocations. More... | |
| void * | text_base |
| The base address of the text section in memory. More... | |
| size_t | text_size |
| The size of the text section. More... | |
| void * | const_base |
| The base address of the const section in memory. More... | |
| void * | eh_base |
| The base address of the eh section in memory. More... | |
| size_t | eh_size |
| The size of the eh section. More... | |
| void * | data_base |
| The base address of the data section in memory. More... | |
| void * | bss_base |
| The base address of the bss section in memory. More... | |
| size_t | bss_size |
| The size of the bss section. More... | |
| size_t | exec_size |
| The amount of executable memory allocated. | |
| void * | entry |
| The entry point of the module. More... | |
| uint32_t | checksum |
| The checksum of the text sections. More... | |
| uint32_t * | sec_num |
| The sec nums of each obj. More... | |
| uint32_t | obj_num |
| The count of elf files in an rtl obj. More... | |
| struct link_map * | linkmap |
| For GDB. More... | |
| void * | loader |
| The file details specific to a loader. More... | |
RTL Object.
There is one for each object module loaded plus one for the base kernel image.
| const char* rtems_rtl_obj_s::aname |
NULL means the object is not in a lib
| void* rtems_rtl_obj_s::bss_base |
Referenced by rtems_rtl_obj_free(), and rtems_rtl_obj_load_sections().
| size_t rtems_rtl_obj_s::bss_size |
Referenced by rtems_rtl_obj_load_sections().
| uint32_t rtems_rtl_obj_s::checksum |
A zero means do not checksum.
| void* rtems_rtl_obj_s::const_base |
| void* rtems_rtl_obj_s::data_base |
| void* rtems_rtl_obj_s::eh_base |
| size_t rtems_rtl_obj_s::eh_size |
| void* rtems_rtl_obj_s::entry |
| uint32_t rtems_rtl_obj_s::flags |
Referenced by rtems_rtl_obj_free(), and rtems_rtl_obj_unresolved().
| const char* rtems_rtl_obj_s::fname |
| int rtems_rtl_obj_s::format |
Referenced by rtems_rtl_obj_alloc().
| size_t rtems_rtl_obj_s::fsize |
| size_t rtems_rtl_obj_s::global_size |
| size_t rtems_rtl_obj_s::global_syms |
| rtems_rtl_obj_sym_t* rtems_rtl_obj_s::global_table |
Referenced by rtems_rtl_symbol_obj_erase().
| rtems_chain_node rtems_rtl_obj_s::link |
Referenced by rtems_rtl_obj_free().
| struct link_map* rtems_rtl_obj_s::linkmap |
For GDB.
| void* rtems_rtl_obj_s::loader |
Referenced by rtems_rtl_elf_unwind_deregister().
| size_t rtems_rtl_obj_s::local_size |
Referenced by rtems_rtl_symbol_obj_erase_local().
| size_t rtems_rtl_obj_s::local_syms |
Local symbol count.
| rtems_rtl_obj_sym_t* rtems_rtl_obj_s::local_table |
Local symbol table.
| uint32_t rtems_rtl_obj_s::obj_num |
| const char* rtems_rtl_obj_s::oname |
| off_t rtems_rtl_obj_s::ooffset |
Referenced by rtems_rtl_elf_file_check(), rtems_rtl_elf_file_load(), and rtems_rtl_rap_file_load().
| uint32_t* rtems_rtl_obj_s::sec_num |
| rtems_chain_control rtems_rtl_obj_s::sections |
Referenced by rtems_rtl_obj_alloc(), rtems_rtl_obj_erase_sections(), and rtems_rtl_obj_synchronize_cache().
| void* rtems_rtl_obj_s::text_base |
| size_t rtems_rtl_obj_s::text_size |
| uint32_t rtems_rtl_obj_s::unresolved |
| uint32_t rtems_rtl_obj_s::users |
