The CPU specific per-CPU control. More...
#include <cpu.h>
Data Fields | |
| uint32_t | isr_dispatch_disable |
| This flag is context switched with each thread. More... | |
The CPU port can place here all state information that must be available and maintained for each processor in the system. This structure must contain at least one field for C/C++ compatibility. In GNU C empty structures have a size of zero. In C++ structures have a non-zero size. In case CPU_PER_CPU_CONTROL_SIZE is defined to zero, then this structure is not used.
| uint32_t CPU_Per_CPU_control::isr_dispatch_disable |
It indicates that THIS thread has an _ISR_Dispatch stack frame on its stack. By using this flag, we can avoid nesting more interrupt dispatching attempts on a previously interrupted thread's stack.
