rtems-4.11.3
score
cpu
sparc
asm.h
1
17
18
* COPYRIGHT:
19
20
* This file is based on similar code found in newlib available
21
* from ftp.cygnus.com. The file which was used had no copyright
22
* notice. This file is freely distributable as long as the source
23
* of the file is noted.
24
25
26
#ifndef _RTEMS_ASM_H
27
#define _RTEMS_ASM_H
28
29
30
* Indicate we are in an assembly file and get the basic CPU definitions.
31
32
33
#ifndef ASM
34
#define ASM
35
#endif
36
37
38
#include <rtems/score/cpu.h>
39
40
41
* Recent versions of GNU cpp define variables which indicate the
42
* need for underscores and percents. If not using GNU cpp or
43
* the version does not support this, then you will obviously
44
* have to define these as appropriate.
45
46
47
/* XXX __USER_LABEL_PREFIX__ and __REGISTER_PREFIX__ do not work on gcc 2.7.0 */
48
/* XXX The following ifdef magic fixes the problem but results in a warning */
49
/* XXX when compiling assembly code. */
50
51
#ifndef __USER_LABEL_PREFIX__
52
#define __USER_LABEL_PREFIX__ _
53
#endif
54
55
#ifndef __REGISTER_PREFIX__
56
#define __REGISTER_PREFIX__
57
#endif
58
59
rtems/concat.h
60
61
/* Use the right prefix for global labels. */
62
63
#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
64
65
/* Use the right prefix for registers. */
66
67
#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
68
69
70
* define macros for all of the registers on this CPU
71
72
* EXAMPLE: #define d0 REG (d0)
73
74
75
76
* Define macros to handle section beginning and ends.
77
78
79
80
#define BEGIN_CODE_DCL .text
81
#define END_CODE_DCL
82
#define BEGIN_DATA_DCL .data
83
#define END_DATA_DCL
84
#define BEGIN_CODE .text
85
#define END_CODE
86
#define BEGIN_DATA
87
#define END_DATA
88
#define BEGIN_BSS
89
#define END_BSS
90
#define END
91
92
93
* Following must be tailor for a particular flavor of the C compiler.
94
* They may need to put underscores in front of the symbols.
95
96
97
#define PUBLIC(sym) .globl SYM (sym)
98
#define EXTERN(sym) .globl SYM (sym)
99
100
101
* Entry for traps which jump to a programmer-specified trap handler.
102
103
104
#define TRAP(_vector, _handler) \
105
mov %psr, %l0 ; \
106
sethi %hi(_handler), %l4 ; \
107
jmp %l4+%lo(_handler); \
108
mov _vector, %l3
109
110
111
* Used for the reset trap to avoid a supervisor instruction
112
113
114
#define RTRAP(_vector, _handler) \
115
mov %g0, %l0 ; \
116
117
118
mov _vector, %l3
119
120
#endif
concat.h
This include file defines ANSI concatenation macros.
