rtems-4.11.3
score
cpu
m68k
m68k
sim.h
1
28
29
* This file was created by John S. Gwynne to support Motorola's 68332 MCU.
30
31
* Redistribution and use in source and binary forms are permitted
32
* provided that the following conditions are met:
33
* 1. Redistribution of source code and documentation must retain
34
* the above authorship, this list of conditions and the
35
* following disclaimer.
36
* 2. The name of the author may not be used to endorse or promote
37
* products derived from this software without specific prior
38
* written permission.
39
40
* This software is provided "AS IS" without warranty of any kind,
41
* either expressed or implied, including, but not limited to, the
42
* implied warranties of merchantability, title and fitness for a
43
* particular purpose.
44
45
46
47
48
#ifndef _RTEMS_M68K_SIM_H
49
#define _RTEMS_M68K_SIM_H
50
51
52
/* SAM-- shift and mask */
53
#undef SAM
54
#define SAM(a,b,c) ((a << b) & c)
55
56
57
* These macros make this file usable from assembly.
58
59
60
#ifdef ASM
61
#define SIM_VOLATILE_USHORT_POINTER
62
#define SIM_VOLATILE_UCHAR_POINTER
63
#else
64
#define SIM_VOLATILE_USHORT_POINTER (volatile unsigned short int * const)
65
#define SIM_VOLATILE_UCHAR_POINTER (volatile unsigned char * const)
66
#endif
67
68
/* SIM_CRB (SIM Control Register Block) base address of the SIM
69
control registers */
70
#ifndef SIM_CRB
71
#if SIM_MM == 0
72
#define SIM_CRB 0x7ffa00
73
#else
/* SIM_MM */
74
#undef SIM_MM
75
#define SIM_MM 1
76
#define SIM_CRB 0xfffa00
77
#endif
/* SIM_MM */
78
#endif
/* SIM_CRB */
79
80
81
#define SIMCR SIM_VOLATILE_USHORT_POINTER(0x00 + SIM_CRB)
82
/* Module Configuration Register */
83
#define EXOFF 0x8000
/* External Clock Off */
84
#define FRZSW 0x4000
/* Freeze Software Enable */
85
#define FRZBM 0x2000
/* Freeze Bus Monitor Enable */
86
#define SLVEN 0x0800
/* Factory Test Model Enabled (ro)*/
87
#define SHEN 0x0300
/* Show Cycle Enable */
88
#define SUPV 0x0080
/* Supervisor/Unrestricted Data Space */
89
#define MM 0x0040
/* Module Mapping */
90
#define IARB 0x000f
/* Interrupt Arbitration Field */
91
92
93
94
#define SIMTR SIM_VOLATILE_USHORT_POINTER(0x02 + SIM_CRB)
95
/* SIM Test Register */
96
/* Used only for factor testing */
97
98
99
100
#define SYNCR SIM_VOLATILE_USHORT_POINTER(0x04 + SIM_CRB)
101
/* Clock Synthesizer Control Register */
102
#define VCO 0x8000
/* Frequency Control (VCO) */
103
#define PRESCALE 0x4000
/* Frequency Control Bit (Prescale) */
104
#define COUNTER 0x3f00
/* Frequency Control Counter */
105
#define EDIV 0x0080
/* ECLK Divide Rate */
106
#define SLIMP 0x0010
/* Limp Mode Status */
107
#define SLOCK 0x0008
/* Synthesizer Lock */
108
#define RSTEN 0x0004
/* Reset Enable */
109
#define STSIM 0x0002
/* Stop Mode SIM Clock */
110
#define STEXT 0x0001
/* Stop Mode External Clock */
111
112
113
114
#define RSR SIM_VOLATILE_UCHAR_POINTER(0x07 + SIM_CRB)
115
/* Reset Status Register */
116
#define EXT 0x0080
/* External Reset */
117
#define POW 0x0040
/* Power-On Reset */
118
#define SW 0x0020
/* Software Watchdog Reset */
119
#define DBF 0x0010
/* Double Bus Fault Reset */
120
#define LOC 0x0004
/* Loss of Clock Reset */
121
#define SYS 0x0002
/* System Reset */
122
#define TST 0x0001
/* Test Submodule Reset */
123
124
125
126
#define SIMTRE SIM_VOLATILE_USHORT_POINTER(0x08 + SIM_CRB)
127
/* System Integration Test Register */
128
129
130
131
132
#define PORTE0 SIM_VOLATILE_UCHAR_POINTER(0x11 + SIM_CRB)
133
#define PORTE1 SIM_VOLATILE_UCHAR_POINTER(0x13 + SIM_CRB)
134
/* Port E Data Register */
135
#define DDRE SIM_VOLATILE_UCHAR_POINTER(0x15 + SIM_CRB)
136
/* Port E Data Direction Register */
137
#define PEPAR SIM_VOLATILE_UCHAR_POINTER(0x17 + SIM_CRB)
138
/* Port E Pin Assignment Register */
139
/* Any bit cleared (zero) defines the corresponding pin to be an I/O
140
pin. Any bit set defines the corresponding pin to be a bus control
141
signal. */
142
143
144
145
#define PORTF0 SIM_VOLATILE_UCHAR_POINTER(0x19 + SIM_CRB)
146
#define PORTF1 SIM_VOLATILE_UCHAR_POINTER(0x1b + SIM_CRB)
147
/* Port F Data Register */
148
#define DDRF SIM_VOLATILE_UCHAR_POINTER(0x1d + SIM_CRB)
149
150
#define PFPAR SIM_VOLATILE_UCHAR_POINTER(0x1f + SIM_CRB)
151
152
153
signal. */
154
155
156
157
#define SYPCR SIM_VOLATILE_UCHAR_POINTER(0x21 + SIM_CRB)
158
/* !!! can write to only once after reset !!! */
159
/* System Protection Control Register */
160
#define SWE 0x80
/* Software Watch Enable */
161
#define SWP 0x40
/* Software Watchdog Prescale */
162
#define SWT 0x30
/* Software Watchdog Timing */
163
#define HME 0x08
/* Halt Monitor Enable */
164
#define BME 0x04
/* Bus Monitor External Enable */
165
#define BMT 0x03
/* Bus Monitor Timing */
166
167
168
169
#define PICR SIM_VOLATILE_USHORT_POINTER(0x22 + SIM_CRB)
170
/* Periodic Interrupt Control Reg. */
171
#define PIRQL 0x0700
/* Periodic Interrupt Request Level */
172
#define PIV 0x00ff
/* Periodic Interrupt Level */
173
174
175
176
#define PITR SIM_VOLATILE_USHORT_POINTER(0x24 + SIM_CRB)
177
/* Periodic Interrupt Timer Register */
178
#define PTP 0x0100
/* Periodic Timer Prescaler Control */
179
#define PITM 0x00ff
/* Periodic Interrupt Timing Modulus */
180
181
182
183
#define SWSR SIM_VOLATILE_UCHAR_POINTER(0x27 + SIM_CRB)
184
/* Software Service Register */
185
/* write 0x55 then 0xaa to service the software watchdog */
186
187
188
189
#define TSTMSRA SIM_VOLATILE_USHORT_POINTER(0x30 + SIM_CRB)
190
/* Test Module Master Shift A */
191
#define TSTMSRB SIM_VOLATILE_USHORT_POINTER(0x32 + SIM_CRB)
192
193
#define TSTSC SIM_VOLATILE_USHORT_POINTER(0x34 + SIM_CRB)
194
/* Test Module Shift Count */
195
#define TSTRC SIM_VOLATILE_USHORT_POINTER(0x36 + SIM_CRB)
196
/* Test Module Repetition Counter */
197
#define CREG SIM_VOLATILE_USHORT_POINTER(0x38 + SIM_CRB)
198
/* Test Module Control */
199
#define DREG SIM_VOLATILE_USHORT_POINTER(0x3a + SIM_CRB)
200
/* Test Module Distributed */
201
202
203
204
205
#define PORTC SIM_VOLATILE_UCHAR_POINTER(0x41 + SIM_CRB)
206
/* Port C Data */
207
208
209
210
#define CSPAR0 SIM_VOLATILE_USHORT_POINTER(0x44 + SIM_CRB)
211
/* Chip Select Pin Assignment
212
Resgister 0 */
213
/* CSPAR0 contains seven two-bit fields that determine the functions
214
of corresponding chip-select pins. CSPAR0[15:14] are not
215
used. These bits always read zero; write have no effect. CSPAR0 bit
216
1 always reads one; writes to CSPAR0 bit 1 have no effect. */
217
#define CSPAR1 SIM_VOLATILE_USHORT_POINTER(0x46 + SIM_CRB)
218
219
Register 1 */
220
/* CSPAR1 contains five two-bit fields that determine the finctions of
221
corresponding chip-select pins. CSPAR1[15:10] are not used. These
222
bits always read zero; writes have no effect. */
223
224
225
* Bit Field | Description
226
227
* 00 | Discrete Output
228
* 01 | Alternate Function
229
* 10 | Chip Select (8-bit port)
230
* 11 | Chip Select (16-bit port)
231
232
#define DisOut 0x0
233
#define AltFun 0x1
234
#define CS8bit 0x2
235
#define CS16bit 0x3
236
237
238
* CSPARx Field |Chip Select Signal | Alternate Signal | Discrete Output
239
240
#define CS_5 12
/* !CS5 | FC2 | PC2 */
241
#define CS_4 10
/* !CS4 | FC1 | PC1 */
242
#define CS_3 8
/* !CS3 | FC0 | PC0 */
243
#define CS_2 6
/* !CS2 | !BGACK | */
244
#define CS_1 4
/* !CS1 | !BG | */
245
#define CS_0 2
/* !CS0 | !BR | */
246
#define CSBOOT 0
/* !CSBOOT | | */
247
248
#define CS_10 8
/* !CS10 | ADDR23 | ECLK */
249
#define CS_9 6
/* !CS9 | ADDR22 | PC6 */
250
#define CS_8 4
/* !CS8 | ADDR21 | PC5 */
251
#define CS_7 2
/* !CS7 | ADDR20 | PC4 */
252
#define CS_6 0
/* !CS6 | ADDR19 | PC3 */
253
254
#define BS_2K 0x0
255
#define BS_8K 0x1
256
#define BS_16K 0x2
257
#define BS_64K 0x3
258
#define BS_128K 0x4
259
#define BS_256K 0x5
260
#define BS_512K 0x6
261
#define BS_1M 0x7
262
263
#define CSBARBT SIM_VOLATILE_USHORT_POINTER(0x48 + SIM_CRB)
264
#define CSBAR0 SIM_VOLATILE_USHORT_POINTER(0x4c + SIM_CRB)
265
#define CSBAR1 SIM_VOLATILE_USHORT_POINTER(0x50 + SIM_CRB)
266
#define CSBAR2 SIM_VOLATILE_USHORT_POINTER(0x54 + SIM_CRB)
267
#define CSBAR3 SIM_VOLATILE_USHORT_POINTER(0x58 + SIM_CRB)
268
#define CSBAR4 SIM_VOLATILE_USHORT_POINTER(0x5c + SIM_CRB)
269
#define CSBAR5 SIM_VOLATILE_USHORT_POINTER(0x60 + SIM_CRB)
270
#define CSBAR6 SIM_VOLATILE_USHORT_POINTER(0x64 + SIM_CRB)
271
#define CSBAR7 SIM_VOLATILE_USHORT_POINTER(0x68 + SIM_CRB)
272
#define CSBAR8 SIM_VOLATILE_USHORT_POINTER(0x6c + SIM_CRB)
273
#define CSBAR9 SIM_VOLATILE_USHORT_POINTER(0x70 + SIM_CRB)
274
#define CSBAR10 SIM_VOLATILE_USHORT_POINTER(0x74 + SIM_CRB)
275
276
#define MODE 0x8000
277
#define Disable 0
278
#define LowerByte 0x2000
279
#define UpperByte 0x4000
280
#define BothBytes 0x6000
281
#define ReadOnly 0x0800
282
#define WriteOnly 0x1000
283
#define ReadWrite 0x1800
284
#define SyncAS 0x0
285
#define SyncDS 0x0400
286
287
#define WaitStates_0 (0x0 << 6)
288
#define WaitStates_1 (0x1 << 6)
289
#define WaitStates_2 (0x2 << 6)
290
#define WaitStates_3 (0x3 << 6)
291
#define WaitStates_4 (0x4 << 6)
292
#define WaitStates_5 (0x5 << 6)
293
#define WaitStates_6 (0x6 << 6)
294
#define WaitStates_7 (0x7 << 6)
295
#define WaitStates_8 (0x8 << 6)
296
#define WaitStates_9 (0x9 << 6)
297
#define WaitStates_10 (0xa << 6)
298
#define WaitStates_11 (0xb << 6)
299
#define WaitStates_12 (0xc << 6)
300
#define WaitStates_13 (0xd << 6)
301
#define FastTerm (0xe << 6)
302
#define External (0xf << 6)
303
304
#define CPUSpace (0x0 << 4)
305
#define UserSpace (0x1 << 4)
306
#define SupSpace (0x2 << 4)
307
#define UserSupSpace (0x3 << 4)
308
309
#define IPLevel_any 0x0
310
#define IPLevel_1 0x2
311
#define IPLevel_2 0x4
312
#define IPLevel_3 0x6
313
#define IPLevel_4 0x8
314
#define IPLevel_5 0xa
315
#define IPLevel_6 0xc
316
#define IPLevel_7 0xe
317
318
#define AVEC 1
319
320
#define CSORBT SIM_VOLATILE_USHORT_POINTER(0x4a + SIM_CRB)
321
#define CSOR0 SIM_VOLATILE_USHORT_POINTER(0x4e + SIM_CRB)
322
#define CSOR1 SIM_VOLATILE_USHORT_POINTER(0x52 + SIM_CRB)
323
#define CSOR2 SIM_VOLATILE_USHORT_POINTER(0x56 + SIM_CRB)
324
#define CSOR3 SIM_VOLATILE_USHORT_POINTER(0x5a + SIM_CRB)
325
#define CSOR4 SIM_VOLATILE_USHORT_POINTER(0x5e + SIM_CRB)
326
#define CSOR5 SIM_VOLATILE_USHORT_POINTER(0x62 + SIM_CRB)
327
#define CSOR6 SIM_VOLATILE_USHORT_POINTER(0x66 + SIM_CRB)
328
#define CSOR7 SIM_VOLATILE_USHORT_POINTER(0x6a + SIM_CRB)
329
#define CSOR8 SIM_VOLATILE_USHORT_POINTER(0x6e + SIM_CRB)
330
#define CSOR9 SIM_VOLATILE_USHORT_POINTER(0x72 + SIM_CRB)
331
#define CSOR10 SIM_VOLATILE_USHORT_POINTER(0x76 + SIM_CRB)
332
333
#endif
/* _RTEMS_M68K_SIM_H */
