SuperH CPU Support. More...
#include <rtems/system.h>#include <rtems/score/isr.h>#include <rtems/score/sh_io.h>#include <rtems/score/cpu.h>#include <rtems/score/sh.h>
| void | _CPU_Initialize (void) |
| CPU initialization. More... | |
| uint32_t | _CPU_ISR_Get_level (void) |
| Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode. More... | |
| void | _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
| This routine installs a "raw" interrupt handler directly into the processor's vector table. More... | |
| void | _CPU_ISR_install_vector (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
| This routine installs an interrupt vector. More... | |
| void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
| This routine is the CPU dependent IDLE thread body. More... | |
| void | _CPU_Context_Initialize (Context_Control *_the_context, void *_stack_base, uint32_t _size, uint32_t _isr, void(*_entry_point)(void), int _is_fp, void *_tls_base) |
| proc_ptr | vectab [] |
| proc_ptr | _Hardware_isr_Table [] |
| uint8_t | _bit_set_table [16] |
SuperH CPU Support.
This file contains information pertaining to the Hitachi SH processor.
| uint8_t _bit_set_table[16] |
