rtems-4.11.3
posix
include
semaphore.h
1
10
11
* COPYRIGHT (c) 1989-2011.
12
* On-Line Applications Research Corporation (OAR).
13
14
* The license and distribution terms for this file may be
15
* found in the file LICENSE in this distribution or at
16
* http://www.rtems.org/license/LICENSE.
17
18
19
#ifndef _SEMAPHORE_H
20
#define _SEMAPHORE_H
21
22
#ifdef __cplusplus
23
extern
"C"
24
#endif
25
34
#include <unistd.h>
35
36
#if defined(_POSIX_SEMAPHORES)
37
38
#include <sys/time.h>
39
40
41
* 11.1 Semaphore Characteristics, P1003.1b-1993, p.219
42
43
typedef
uint32_t sem_t;
44
45
46
* Bad semaphore Id
47
48
#define SEM_FAILED ((sem_t *)0)
49
50
51
* 11.2.1 Initialize an Unnamed Semaphore, P1003.1b-1993, p.219
52
53
int
sem_init(
54
sem_t *sem,
55
int
pshared,
56
unsigned
int
value
57
58
64
int
sem_destroy(
65
sem_t *sem
66
67
68
69
* 11.2.3 Initialize/Open a Named Semaphore, P1003.1b-1993, p.221
70
71
* NOTE: Follows open() calling conventions.
72
73
sem_t *sem_open(
74
const
char
*name,
75
int
oflag,
76
77
78
86
int
sem_close(
87
sem_t *sem
88
89
98
int
sem_unlink(
99
const
char
*name
100
101
109
int
sem_wait(
110
sem_t *sem
111
112
118
int
sem_trywait(
119
sem_t *sem
120
121
122
#if defined(_POSIX_TIMEOUTS)
123
126
int
sem_timedwait(
127
sem_t *__restrict sem,
128
const
struct
timespec *__restrict timeout
129
130
#endif
131
137
int
sem_post(
138
sem_t *sem
139
140
146
int
sem_getvalue(
147
148
int
*__restrict sval
149
150
151
#endif
/* _POSIX_SEMAPHORES */
152
153
#ifdef __cplusplus
154
155
#endif
156
157
#endif
158
/* end of include file */
