Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
cpu.h File Reference
Intel I386 CPU Dependent Source. More...
#include <rtems/score/types.h>
#include <rtems/score/i386.h>
#include <rtems/score/interrupts.h>
#include <rtems/score/registers.h>
Include dependency graph for cpu.h:
struct  Context_Control
 This defines the minimal set of integer and processor state registers that must be saved during a voluntary context switch from one thread to another. More...
struct  Context_Control_fp
 This defines the complete set of floating point registers that must be saved during any context switch from one thread to another. More...
struct  CPU_Exception_frame
 The set of registers that specifies the complete processor state. More...
#define CPU_INLINE_ENABLE_DISPATCH   TRUE
#define CPU_SIMPLE_VECTORED_INTERRUPTS   FALSE
#define CPU_HAS_SOFTWARE_INTERRUPT_STACK   TRUE
#define CPU_HAS_HARDWARE_INTERRUPT_STACK   FALSE
#define CPU_ALLOCATE_INTERRUPT_STACK   TRUE
#define CPU_ISR_PASSES_FRAME_POINTER   0
#define CPU_HARDWARE_FP   FALSE
#define CPU_SOFTWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   FALSE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   TRUE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_STRUCTURE_ALIGNMENT
#define CPU_TIMESTAMP_USE_INT64_INLINE   TRUE
#define CPU_PROVIDES_IDLE_THREAD_BODY   TRUE
#define CPU_BIG_ENDIAN   FALSE
#define CPU_LITTLE_ENDIAN   TRUE
#define CPU_PER_CPU_CONTROL_SIZE   0
#define I386_CONTEXT_CONTROL_EFLAGS_OFFSET   0
#define I386_CONTEXT_CONTROL_ESP_OFFSET   4
#define I386_CONTEXT_CONTROL_EBP_OFFSET   8
#define I386_CONTEXT_CONTROL_EBX_OFFSET   12
#define I386_CONTEXT_CONTROL_ESI_OFFSET   16
#define I386_CONTEXT_CONTROL_EDI_OFFSET   20
#define _CPU_Context_Get_SP(_context)   (_context)->esp
#define CPU_CONTEXT_FP_SIZE   sizeof( Context_Control_fp )
#define CPU_MODES_INTERRUPT_LEVEL   0x00000001 /* interrupt level in mode */
#define CPU_MODES_INTERRUPT_MASK   0x00000001 /* interrupt level in mode */
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   1024
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
#define CPU_STACK_MINIMUM_SIZE   4096
#define CPU_SIZEOF_POINTER   4
#define CPU_ALIGNMENT   4
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_PARTITION_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   16
#define _CPU_ISR_Disable(_level)   i386_disable_interrupts( _level )
#define _CPU_ISR_Enable(_level)   i386_enable_interrupts( _level )
#define _CPU_ISR_Flash(_level)   i386_flash_interrupts( _level )
#define _CPU_ISR_Set_level(_new_level)
#define _CPU_Interrupt_stack_setup(_lo, _hi)
#define CPU_EFLAGS_INTERRUPTS_ON   0x00003202
#define CPU_EFLAGS_INTERRUPTS_OFF   0x00003002
#define _CPU_Context_Initialize(_the_context, _stack_base, _size, _isr, _entry_point, _is_fp, _tls_area)
#define _CPU_Context_Restart_self(_the_context)   _CPU_Context_restore( (_the_context) );
#define _CPU_Context_Fp_start(_base, _offset)   ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
#define _CPU_Context_Initialize_fp(_fp_area)
#define _CPU_Fatal_halt(_source, _error)
#define CPU_USE_GENERIC_BITFIELD_CODE   FALSE
#define CPU_USE_GENERIC_BITFIELD_DATA   FALSE
#define _CPU_Bitfield_Find_first_bit(_value, _output)
#define _CPU_Priority_Mask(_bit_number)   ( 1 << (_bit_number) )
#define _CPU_Priority_bits_index(_priority)   (_priority)
typedef void(* cpuExcHandlerType) (CPU_Exception_frame *)
typedef void CPU_Interrupt_frame
typedef uint32_t CPU_Counter_ticks
enum  Intel_symbolic_exception_name {
  I386_EXCEPTION_DIVIDE_BY_ZERO = 0, I386_EXCEPTION_DEBUG = 1, I386_EXCEPTION_NMI = 2, I386_EXCEPTION_BREAKPOINT = 3,
  I386_EXCEPTION_OVERFLOW = 4, I386_EXCEPTION_BOUND = 5, I386_EXCEPTION_ILLEGAL_INSTR = 6, I386_EXCEPTION_MATH_COPROC_UNAVAIL = 7,
  I386_EXCEPTION_DOUBLE_FAULT = 8, I386_EXCEPTION_I386_COPROC_SEG_ERR = 9, I386_EXCEPTION_INVALID_TSS = 10, I386_EXCEPTION_SEGMENT_NOT_PRESENT = 11,
  I386_EXCEPTION_STACK_SEGMENT_FAULT = 12, I386_EXCEPTION_GENERAL_PROT_ERR = 13, I386_EXCEPTION_PAGE_FAULT = 14, I386_EXCEPTION_INTEL_RES15 = 15,
  I386_EXCEPTION_FLOAT_ERROR = 16, I386_EXCEPTION_ALIGN_CHECK = 17, I386_EXCEPTION_MACHINE_CHECK = 18, I386_EXCEPTION_ENTER_RDBG = 50
void rtems_exception_init_mngt (void)
uint32_t _CPU_ISR_Get_level (void)
 Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode. More...
void _CPU_Initialize (void)
 CPU initialization. More...
void _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
 This routine installs a "raw" interrupt handler directly into the processor's vector table. More...
void _CPU_ISR_install_vector (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
 This routine installs an interrupt vector. More...
void * _CPU_Thread_Idle_body (uintptr_t ignored)
 This routine is the CPU dependent IDLE thread body. More...
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context. More...
void _CPU_Context_restore (Context_Control *new_context)
 This routine is generally used only to restart self in an efficient manner. More...
void _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr)
 This routine saves the floating point context passed to it. More...
void _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr)
 This routine restores the floating point context passed to it. More...
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
 Prints the exception frame via printk(). More...
CPU_Counter_ticks _CPU_Counter_read (void)
cpuExcHandlerType _currentExcHandler
SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context
This include file contains information pertaining to the Intel i386 processor.
◆ _CPU_Bitfield_Find_first_bit
#define _CPU_Bitfield_Find_first_bit (   _value,
  _output
Value:
register uint16_t __value_in_register = (_value); \
_output = 0; \
__asm__ volatile ( "bsfw %0,%1 " \
: "=r" (__value_in_register), "=r" (_output) \
: "0" (__value_in_register), "1" (_output) \
◆ _CPU_Context_Initialize
#define _CPU_Context_Initialize (   _the_context,
  _stack_base,
  _size,
  _isr,
  _entry_point,
  _is_fp,
  _tls_area
Value:
do { \
uint32_t _stack; \
(void) _is_fp; /* avoid warning for being unused */ \
if ( (_isr) ) (_the_context)->eflags = CPU_EFLAGS_INTERRUPTS_OFF; \
else (_the_context)->eflags = CPU_EFLAGS_INTERRUPTS_ON; \
_stack = ((uint32_t)(_stack_base)) + (_size); \
_stack &= ~ (CPU_STACK_ALIGNMENT - 1); \
_stack -= 2*sizeof(proc_ptr*); /* see above for why we need to do this */ \
*((proc_ptr *)(_stack)) = (_entry_point); \
(_the_context)->ebp = (void *) 0; \
(_the_context)->esp = (void *) _stack; \
} while (0)
This number corresponds to the byte alignment requirement for the stack.
Definition: cpu.h:659
void * proc_ptr
XXX: Eventually proc_ptr needs to disappear!!!
Definition: basedefs.h:329
◆ _CPU_Context_Initialize_fp
#define _CPU_Context_Initialize_fp (   _fp_area)
Value:
memcpy( *_fp_area, &_CPU_Null_fp_context, CPU_CONTEXT_FP_SIZE ); \
This variable is optional.
Definition: cpu.h:494
The size of the floating point context area.
Definition: cpu.h:539
◆ _CPU_Fatal_halt
#define _CPU_Fatal_halt (   _source,
  _error
Value:
uint32_t _error_lvalue = ( _error ); \
__asm__ volatile ( "cli ; \ movl %0,%%eax ; \ hlt" \
: "=r" ((_error_lvalue)) : "0" ((_error_lvalue)) \
◆ _CPU_Interrupt_stack_setup
#define _CPU_Interrupt_stack_setup (   _lo,
  _hi
Value:
do { \
_hi = (void*)(((uintptr_t)(_hi) - 4) & ~ (CPU_STACK_ALIGNMENT - 1)); \
} while (0)
◆ _CPU_ISR_Set_level
#define _CPU_ISR_Set_level (   _new_level)
Value:
if ( _new_level ) __asm__ volatile ( "cli" ); \
else __asm__ volatile ( "sti" ); \
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
